0 members (),
207
Mod | | | Forums66 Topics128,143 Posts1,056,494 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2009 Posts: 90 Shop Shark | | Shop Shark Joined: Jul 2009 Posts: 90 | Hello all,
I have a '57 Chevrolet (car) with a 235 straight six. I just installed a factory overdrive and love it but because of the free wheeling option it means I come up to red lights as though I have my foot on the clutch the whole time.
When I come up to the red lights this way the car wants to die. It will start back. I think perhaps the carb (original 1 barrel) needs some adjustment. Does anyone have a good description of how to tune one of these carbs? I don't know much about how to set up a carb.
Thanks, Brandon | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | here'a a manual, that covers the operation of the OD in the transmission chapter, and also the carb, if it does need attention Bill | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | I don't like red lights either | | | | | Joined: Jul 2009 Posts: 90 Shop Shark | | Shop Shark Joined: Jul 2009 Posts: 90 | I think the 55 used a different carb. I guess it would still be the same basic operation though, right?
Thanks, Brandon | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the manual linked is for the 2nd series 55-59 truck, any differences from the 57 car will be trivial, transmissions are near identical and carb function the same
Bill | | | | | Joined: Jul 2009 Posts: 90 Shop Shark | | Shop Shark Joined: Jul 2009 Posts: 90 | | | | | | Joined: Dec 2007 Posts: 12 New Guy | | New Guy Joined: Dec 2007 Posts: 12 | I had the same problem in freewheeling mode when coming to a stop. I found my idle mixture set too lean. I adjusted the idle mixture slightly richer to solve the problem.
