1 members (baldeagle),
69
Mod | | | Forums66 Topics128,037 Posts1,055,467 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2012 Posts: 18 New Guy | | New Guy Joined: Feb 2012 Posts: 18 | First post on this forum. Am the proud owner of a 1950 3100. Purchased in CA last week. Nice condition, decent driver. I look forward to the projects ahead. One question. Upon acceleration I hear a slight whistle coming from carburator. Have done some research and have read that this may be a vacuum leak in throttle shaft. Any input would be welcome. Thanks, kurtf | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Hi Kurt,firstly welcome from a fellow '50 owner which,coincidentally came from Ca. but is a long way from home now.
It sounds like you're on the right track re; the whistling,but try posting this same question in the engine sub-forum,not all the engine gurus check in here. I'm sure you'll get a better response and help to cure your problem. Good luck. Jock.
1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | Willkommen, I guessing by your handle that you are German, welcome. Does this whistle happen when you drive past the pretty girls?
Hey Kurt, good luck with your new acquisition, hope you can get that fixed and on to other things.
Leo | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Welcome to the stovebolt. Look forward so seeing you around the garage. | | |
