8 members (Donf, 57 Drifter, baldeagle, HandyAndy, gswbbc, tclederman, Cosmo, 1 invisible), 122 guests, and 2 robots.
Topics128,040
Posts1,055,478
Members48,424
#829162 02/24/2012 12:51 AM
Trying to find info on the PTO unit for a 1940 Chevy 2 ton and info or pictures would help HAVE A LEVER DOWN BY THE DRIVER SEAT ON THE FLOOR but not hook up
Gerard
1940 Chevy 2-Ton (Canadian)webshots albertachevy
I have contacts with two of the PTO manufacturers and neither is really of much help with units this old. I'll be happy to help however if you send the PTO model you have. Or do you have one? You really don't say what you want.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
53moneypit #829609 02/25/2012 2:55 PM
Dave,
I sent you an email with a picture of two PTO's I just got off of SM-420 transmissions, did you get it? Sent it last week...might be in you spam folder. Was hoping you could tell me something about them.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Mike B #830041 02/26/2012 11:10 PM
Yes I got them. It had another name not the one you use here. I haven't had time to get into it.
Dave
53moneypit #830075 02/27/2012 1:14 AM
OK, Thanks, no rush...
I cleaned them both up the other day and they look good...no additional info was found.
Mike B
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
Mike B #830168 02/27/2012 5:24 AM
off topic does any one know how long the rubber stopper on the spring hangers is the one that stops the spring from beating [censored] out the frame my truck is 45 chevy 2 ton
Ralphie #830211 02/27/2012 2:10 PM
Way off topic, please start a new thread about bumpstops..
Grigg #830665 02/28/2012 8:18 PM
alberta chevy: I've managed to impress myself once again with my ability to loose things and/or misplace them. Such a dummy. That's what has happened with the pictures you sent but from what I remember they appear to be old cast iron Spicers and are single gear (obviously) and lever shift. Std SAE 6 bolt configuration. I think they are spur gears (meaning straight cut). So I really don't know what it is you want but if it's repair parts then as for seals there is no problem at almost any industrial seal supplier and as for the gaskets they are still the same today so again no problem.
Dave
