| | | Forums66 Topics128,040 Posts1,055,478 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2007 Posts: 24 New Guy | | New Guy Joined: Aug 2007 Posts: 24 | Trying to find info on the PTO unit for a 1940 Chevy 2 ton and info or pictures would help HAVE A LEVER DOWN BY THE DRIVER SEAT ON THE FLOOR but not hook up | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | I have contacts with two of the PTO manufacturers and neither is really of much help with units this old. I'll be happy to help however if you send the PTO model you have. Or do you have one? You really don't say what you want. | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Dave, I sent you an email with a picture of two PTO's I just got off of SM-420 transmissions, did you get it? Sent it last week...might be in you spam folder. Was hoping you could tell me something about them. Thanks, Mike B  | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Yes I got them. It had another name not the one you use here. I haven't had time to get into it. | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | OK, Thanks, no rush...
I cleaned them both up the other day and they look good...no additional info was found.
Mike B | | | | | Joined: Jan 2012 Posts: 18 New Guy | | New Guy Joined: Jan 2012 Posts: 18 | off topic does any one know how long the rubber stopper on the spring hangers is the one that stops the spring from beating [censored] out the frame my truck is 45 chevy 2 ton | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | off topic does any one know how long the rubber stopper on the spring hangers is the one that stops the spring from beating [censored] out the frame my truck is 45 chevy 2 ton Way off topic, please start a new thread about bumpstops.. | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | alberta chevy: I've managed to impress myself once again with my ability to loose things and/or misplace them. Such a dummy. That's what has happened with the pictures you sent but from what I remember they appear to be old cast iron Spicers and are single gear (obviously) and lever shift. Std SAE 6 bolt configuration. I think they are spur gears (meaning straight cut). So I really don't know what it is you want but if it's repair parts then as for seals there is no problem at almost any industrial seal supplier and as for the gaskets they are still the same today so again no problem. | | |
