I'm looking to buy a new ring/pinion set to reduce my final gear ratio for highway cruising. 3.55:1 ratios are pretty common but I found a couple of gear shops that offer 3.38:1 ratio for these 1/2 ton 8.2 dropout rear-ends.
Here is one:
http://www.tomsdifferentials.com/2011catalog/Pages13.pdfI crunched the numbers for cruising along at 65 mph (typical speed limit in my area), and 3.38 would get my RPMs down to 2650 from 3000+ that I'm currently getting with the stock 3.9:1 gears.
Anyone run 3.38:1 with the ole thriftmaster 235? My bone stock 235 feels like it's strong enough to handle a taller ratio. Any other suggestions that wont break the bank?
I've got a granny 1st gear, so I'm not worried about take offs and I'm not going to be climbing any mountains or towing anything around. Just looking to give my weekend warrior a little better highway manners.
I've considered the T5 upgrade path, but I really like the stomp to start pedal ('55), and the three on the tree is just fine with me. Besides, I've got such an original truck that I'd hate to modify it too much.
