2 members (gswbbc, wilbur53),
139
Mod | | | Forums66 Topics128,035 Posts1,055,446 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2012 Posts: 4 New Guy | | New Guy Joined: Feb 2012 Posts: 4 | Hey everybody I'm just starting on a 49 project. I'm going to build a daily driver, and like everyone else, $5.00 a gal gas is a concern. I have a 283, and was thinking about mating it to a T-5, or a T-56 transmission. Just wondered if anyone else has tried this combination. I'm not wanting a hot rod truck, just something that has decent power, and I can afford to drive on the highway. Your thoughts? | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | What do you have now? 3100, 3600, ??
~Jim
| | | | | Joined: Feb 2012 Posts: 4 New Guy | | New Guy Joined: Feb 2012 Posts: 4 | it's a 3100. I'm going with mustang frint suspension, and a camaro disc brake rear end. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | A late seventy's early eighty's Camero 10 bolt will match the 2002 Firebird rear disc.
~Jim
| | | | | Joined: Feb 2012 Posts: 4 New Guy | | New Guy Joined: Feb 2012 Posts: 4 | Just got a phone call from a buddy, he found me a good 79 trans am disc brake posi rear end for a hundred bucks. I believe it is the same width as camaro rear end. Thanks for the info btw | | | | | Joined: Dec 2009 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2009 Posts: 66 | Just my 2 cents. What are the gears in the rear end. I think you should consider this if gas price is a concern. Al V. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | The 10 bolt I bought came out of a 80 Camaro and the gears were shot. I bought a set of 2.73 on Ebay and after installing them decided I wanted a bit lower ratio so I bought a set of 3.73 gears. I still have them and probably won't ever use them if the 2.73's prove OK. Unless you plan on racing a higher gear set will help with fuel consumption. And yes the Trans AM is the same width 62".
~Jim
| | | | | Joined: Feb 2012 Posts: 4 New Guy | | New Guy Joined: Feb 2012 Posts: 4 | This one is a 273. The gears look good. Car had been sitting under a shed with no engine or tranny for years. I'm just hoping this gear ratio isn't a too tall for the little 283. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I wouldn't worry about that. If it is you can always swap it out for something that works better.
~Jim
| | | | | Joined: Feb 2009 Posts: 400 'Bolter | | 'Bolter Joined: Feb 2009 Posts: 400 | I used a nova rear with 2.73 and 283 motor with 2bbl carb and turbo 400, was getting 22 mpg, totally different vehicle tho. | | |
