4 members (baldeagle, Peggy M, tclederman, TexasJim50), 100 guests, and 4 robots.
Topics128,018
Posts1,055,342
Members48,419
#828413 02/21/2012 12:39 PM
Hey everybody
I'm just starting on a 49 project. I'm going to build a daily driver, and like everyone else, $5.00 a gal gas is a concern. I have a 283, and was thinking about mating it to a T-5, or a T-56 transmission. Just wondered if anyone else has tried this combination. I'm not wanting a hot rod truck, just something that has decent power, and I can afford to drive on the highway. Your thoughts?
pappy yokum #828738 02/22/2012 3:38 PM
What do you have now? 3100, 3600, ??
~Jim
it's a 3100. I'm going with mustang frint suspension, and a camaro disc brake rear end.
pappy yokum #828787 02/22/2012 8:42 PM
A late seventy's early eighty's Camero 10 bolt will match the 2002 Firebird rear disc.
~Jim
Just got a phone call from a buddy, he found me a good 79 trans am disc brake posi rear end for a hundred bucks. I believe it is the same width as camaro rear end. Thanks for the info btw
pappy yokum #828819 02/22/2012 10:21 PM
Just my 2 cents. What are the gears in the rear end. I think you should consider this if gas price is a concern.
Al V.
APV60 #828824 02/22/2012 10:39 PM
The 10 bolt I bought came out of a 80 Camaro and the gears were shot. I bought a set of 2.73 on Ebay and after installing them decided I wanted a bit lower ratio so I bought a set of 3.73 gears. I still have them and probably won't ever use them if the 2.73's prove OK. Unless you plan on racing a higher gear set will help with fuel consumption.
And yes the Trans AM is the same width 62".
~Jim
This one is a 273. The gears look good. Car had been sitting under a shed with no engine or tranny for years. I'm just hoping this gear ratio isn't a too tall for the little 283.
pappy yokum #828931 02/23/2012 5:30 AM
I wouldn't worry about that. If it is you can always swap it out for something that works better.
~Jim
I used a nova rear with 2.73 and 283 motor with 2bbl carb and turbo 400, was getting 22 mpg, totally different vehicle tho.
1953 Chevy Two-Ton
More pix on Photobucket
Be careful calling yourself a expert,because an "EX" is a hasbeen and a"SPERT" is a drip under pressure.
