| | | Forums66 Topics128,193 Posts1,057,244 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Research on the spare tire hangar for my pickup has turned almost nothing in the Chevy literature. Although getting help from fellow Bolters, there are no images within the owner's manual, shop manual or my old 42 Chevy parts manual. I have seen some factory drawings and while similar they do not show all the parts that came with this truck over 30 years ago and I believe they are correct and complete. I'll post a link so you guys can have a look. Any info would be appreciated. http://rides.webshots.com/album/582371665xpYwSg
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | I bought one of those off e bay a few years ago. I'm using it on my 50.
I could not find that style carrier in the 47-54 factory assembly manual, Hopefully someone will have some info for you
What is the item under the j hook in the second pic? | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | DADS50, That item is the factory lock, it's a cast iron piece and locks on to a special nut on the 'J' hook. I believe this lock was used on later years also. The locks are getting hard to find and expensive. FOUND PICS-in my old 41 Salesmens Truck data book, pics of light duty and 3/4 ton tire carrier called Monorail carrier. Also checked in my 42 parts manual, no pics but part numbers are the same for 41 and 42, see attached Webshots link. http://rides.webshots.com/album/582371665xpYwSg
| | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Here's an even better picture found online Keith Hardy's manuals. 41 Advance Service info, pg. 115. http://chevy.oldcarmanualproject.com/manuals/1941asi/41asi115.htmAlso go to page 116 for a description of the parts.
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Thank you for the info on the lock
that is a pretty rare item.
| | | | | Joined: Feb 2010 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2010 Posts: 54 | I have an original low mileage 46 and would be glad to answer any questions by looking at mine. (measurements etc) Call me tomorrow if I can help. 931-455-7072
Monroe McKill
| | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Thanks guys for all the help on this and believe I've this all sorted out. Still would like to se a detailed blow up out of a Chevy parts book which may show all the associated parts. I'm thinking a 1941 parts manual may have such a drawing. Have three of you now that confirm this type of carrier system I've shown is what's on their 41-46 pickups. http://rides.webshots.com/album/582371665xpYwSghttp://chevy.oldcarmanualproject.com/manuals/1941asi/41asi115.htm (also see pg 116) Regards Jim
