4 members (Donf, msmall, 2 invisible),
120
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,189 Posts1,057,337 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2010 Posts: 304 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 304 | Apparently there are two heater motors for a 52 3100. I just bought one from Classic parts and it is not correct. They only list one motor. (6 volt or 12 volt) After further review I see that LMC only sells one model for a 52. Lmc does list a second one for a delux heater, but those fit 55-59. Jim Carter has a little more accurate description. There's says 47-66, 12 volt,with a 1/4" shaft, for the recirculator round core housings. Then they list one for the delux fresh air model, 12 volt 5/16" shaft. So for us that don't know about these heater motors- measure the shaft diameter first, before ordering, because only one out of three of these parts companies tells you about or even offers the difference.
'52 3100 "once a Marine, always a Marine!! | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | or better yet, take the original motor to a FLAPS and match the dimensions in whatever voltage - NAPA lists a selection
Bill | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | I did what Bill says for my 52,went to CJC I work part time there and left the 6 volt with one of the counter guys when I got back from one of my deliverys they already had a matching one in 12volt.I wish I had kept the end box so I'd have the # but I didn't.
Pete | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I'm calling from memory right now but I think I ended up with a 12V that comes from a '66 with A/C to get the right shaft. There ia little difference but it will fit right in there. | | | | | Joined: Mar 2007 Posts: 4,217 Moderator | | Moderator Joined: Mar 2007 Posts: 4,217 | My old heater had a shaft that stuck out each end of the motor. One end had a squirrel cage and the other end had a 4 blade fan. I ordered the Jim Carter motor, the shaft was the correct diameter, but it only came out the one end. My heater apparently came out of a late 40s Chev car, but it's all bolted in now and working. The Carter catalogue does warn about shaft diameter. | | | | | Joined: Nov 2010 Posts: 304 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 304 | Thanks for the replies. Good info.
