7 members (68ironhead, Bill Hanlon, Joe H, Chris's 46 / 515, Pre '68 Dave, pauld, 1 invisible), 52 guests, and 2 robots.
Topics128,185
Posts1,057,279
Members48,467
Apparently there are two heater motors for a 52 3100. I just bought one from Classic parts and it is not correct. They only list one motor. (6 volt or 12 volt) After further review I see that LMC only sells one model for a 52. Lmc does list a second one for a delux heater, but those fit 55-59. Jim Carter has a little more accurate description. There's says 47-66, 12 volt,with a 1/4" shaft, for the recirculator round core housings. Then they list one for the delux fresh air model, 12 volt 5/16" shaft. So for us that don't know about these heater motors- measure the shaft diameter first, before ordering, because only one out of three of these parts companies tells you about or even offers the difference.
'52 3100 "once a Marine, always a Marine!!
or better yet, take the original motor to a FLAPS and match the dimensions in whatever voltage - NAPA lists a selection
I did what Bill says for my 52,went to CJC I work part time there and left the 6 volt with one of the counter guys when I got back from one of my deliverys they already had a matching one in 12volt.I wish I had kept the end box so I'd have the # but I didn't.
Pete
I'm calling from memory right now but I think I ended up with a 12V that comes from a '66 with A/C to get the right shaft. There ia little difference but it will fit right in there.
Leo Offline
Moderator
Moderator
My old heater had a shaft that stuck out each end of the motor. One end had a squirrel cage and the other end had a 4 blade fan. I ordered the Jim Carter motor, the shaft was the correct diameter, but it only came out the one end. My heater apparently came out of a late 40s Chev car, but it's all bolted in now and working. The Carter catalogue does warn about shaft diameter.
Thanks for the replies. Good info.
