10 members (Otto Skorzeny, carbking, 55shaker, fonz8261, Greg_H, Hotrod Lincoln, Cletus1950, Peggy M, 2 invisible),
148
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,131 Posts1,056,721 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | antifreeze on the floorboard in my 1965 C10... hmn, that's not supposed to be there.
Coolant dripping out of the heater itself and onto the floor... then I check under the hood and it's dripping out there too and onto the frame rail.
I'm suspecting the heater core... now, I just gotta figure out how to take it out.
Now perusing section 13 in my '63 and '65 shop manuals. I haven't made it over to the assembly manual yet.
This looks like I am in for some cussin'.
-W
| | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | Well, on the bright side, you won't be laying on your back, upside down in the cab like you would on newer trucks.  Good luck, and of course we'll be expecting a photo journal of the repair. | | | | | Joined: Dec 2008 Posts: 319 Shop Shark | | Shop Shark Joined: Dec 2008 Posts: 319 | I think the cleanup will be harder than changing out the core. Just be sure to get the right one, I think there's 3 different cores.
cm If you can't fix it with a hammer and screwdriver, you need a bigger hammer.1965 Chevy C10 | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | Remove the two speed nuts on the inside of the cab, behind the under-hood box, allowing the under-hood box to be removed from the firewall, upon removing the 5 hex-head lag screws, from the snorkel of the under-hood box, affixing it to the firewall. This must be done, in order to access the four tiny 1/4" head lag screws on the back of the under-hood box, along with the numerous others around the perimeter of the top cover, thus allowing the box to split apart, exposing the heater core.
Perhaps this will eliminate some of the cussing! Good luck and keep us posted.
| | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | Geez Tony,
that's exactly what I needed to know... before I started.
ha ha ha. Thanks a bunch for the reply tho'! You musta posted that right after I checked this thread earlier.
That is exactly what you must do folks!
O'Reillys has this in their system :
Murray - Heater Core Part Number: 398224
I ordered one, we'll see if it fits tomorrow.
-W | | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | Well, that part fit my application... and I put some new hoses on there as well and buttoned it all back up. So far, so good. I hope that fixed it.
The duct work tube on the passenger side came apart, unwound and started looking like a slinky. I duct taped it back together until I can get some new ones.
-W | | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | my heater box reassembly photos... -W p.s. after perusing a few vendor parts sites that sell pieces for our trucks... most of 'em want around 75-85 dollars for the same heater core. O'Reilly had it for $34.xx(tax included). Maybe the vendor ones are precise exact copies or something? I dunno, but thought I'd add that in here. | | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | Thanks for the photos. It has been so long since y heater came out, good review for putting it back in. | | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | Thanks for the photos. It has been so long since my heater came out, good review for putting it back in. | | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | Hambone - your '62 might be a little different, they changed some things along the way within the heater box, according to the shop manuals. The main assembly is probably very similar tho'.
-W | | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | I wandered into this old thread of mine and noticed the URL for the photos up above was no longer good... this post here has the current URL for the photos. my heater box reassembly photos... -W April 2015 | | | | | Joined: Apr 2005 Posts: 313 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 313 | I just replaced mine a few months ago. Got a heater core at Advance Auto for $34.00, and installed it in less than a hour. I did have to make slight modifications for proper fit. | | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | Nice diagram and article _____ John | | |
