7 members (dt235sd, RdsLessTaken, Gazz, Woodcmiami, Charles in CA, TexasA&M48Truck, BC59), 100 guests, and 2 robots.
Topics128,094
Posts1,056,483
Members48,444
#826593 02/15/2012 11:07 PM
Hi getting ready to drop a V-8 into my 37 but i have a prob i got the nuts off the bolts under the nose but now there are two really thick washers and springs are those washers threaded or just really rusted on trying not to destroy all that as i would like to reuse them but at this point i can't tell how it comes off
1937 1/2 ton
My mind may be fuzzy as its been a long time since I took any out. But washers should come off ....OR when you say THICK it may be a "thick" bushing that comes down from above. I THINK what you see may need to be pushed UP and out.......
....clean it and take a good long look. They could be "line up pins?? Someone else may have the SURE answer.
Daniel
I am not understanding your description. Could you post a photo or two? I removed the grill work on my '37 two or so years ago and don't recall seeing thick washers and springs. I took a load of photos before and after, so I may be able to post some that match the views you need????
lol 37blue there is no link on your profile to your webshots or where ever your before and afters are stored i will try to snap some pics later today
1937 1/2 ton
