3 members (KEVINSKI, Bill Hanlon, JW51), 229 guests, and 1 robot.
Topics128,101
Posts1,056,180
Members48,436
#827114 02/17/2012 10:22 AM
Socket Breaker
Socket Breaker
antifreeze on the floorboard in my 1965 C10... hmn, that's not supposed to be there.
Coolant dripping out of the heater itself and onto the floor... then I check under the hood and it's dripping out there too and onto the frame rail.
I'm suspecting the heater core... now, I just gotta figure out how to take it out.
Now perusing section 13 in my '63 and '65 shop manuals. I haven't made it over to the assembly manual yet.
This looks like I am in for some cussin'.
-W
Well, on the bright side, you won't be laying on your back, upside down in the cab like you would on newer trucks. thumbs_up
Good luck, and of course we'll be expecting a photo journal of the repair.
I think the cleanup will be harder than changing out the core. Just be sure to get the right one, I think there's 3 different cores.
cm
If you can't fix it with a hammer and screwdriver, you need a bigger hammer.
1965 Chevy C10
Remove the two speed nuts on the inside of the cab, behind the under-hood box, allowing the under-hood box to be removed from the firewall, upon removing the 5 hex-head lag screws, from the snorkel of the under-hood box, affixing it to the firewall. This must be done, in order to access the four tiny 1/4" head lag screws on the back of the under-hood box, along with the numerous others around the perimeter of the top cover, thus allowing the box to split apart, exposing the heater core.
Perhaps this will eliminate some of the cussing! Good luck and keep us posted.
Socket Breaker
Socket Breaker
Geez Tony,
that's exactly what I needed to know... before I started.
ha ha ha. Thanks a bunch for the reply tho'!
You musta posted that right after I checked this thread earlier.
That is exactly what you must do folks!
O'Reillys has this in their system :
Murray - Heater Core
Part Number: 398224
I ordered one, we'll see if it fits tomorrow.
-W
Socket Breaker
Socket Breaker
Well, that part fit my application... and I put some new hoses on there as well and buttoned it all back up. So far, so good. I hope that fixed it.
The duct work tube on the passenger side came apart, unwound and started looking like a slinky. I duct taped it back together until I can get some new ones.
-W
Socket Breaker
Socket Breaker
my heater box reassembly photos...
-W
p.s. after perusing a few vendor parts sites that sell pieces for our trucks... most of 'em want around 75-85 dollars for the same heater core.
O'Reilly had it for $34.xx(tax included).
Maybe the vendor ones are precise exact copies or something? I dunno, but thought I'd add that in here.
Thanks for the photos. It has been so long since y heater came out, good review for putting it back in.
~ HB
1962 Chevrolet C10
1962 Suburban
Thanks for the photos. It has been so long since my heater came out, good review for putting it back in.
~ HB
1962 Chevrolet C10
1962 Suburban
Socket Breaker
Socket Breaker
Hambone - your '62 might be a little different, they changed some things along the way within the heater box, according to the shop manuals. The main assembly is probably very similar tho'.
-W
Socket Breaker
Socket Breaker
I wandered into this old thread of mine and noticed the URL for the photos up above was no longer good... this post here has the current URL for the photos.
-W
April 2015
I just replaced mine a few months ago. Got a heater core at Advance Auto for $34.00, and installed it in less than a hour. I did have to make slight modifications for proper fit.
Socket Breaker
Socket Breaker
Thought I'd add this in here too...
fellow stove-bolter Burgie - wonderful heater assembly article for our trucks
Even tho' I have it linked on my page there... for folks who do future searches.
-W
Nice diagram and article thumbs_up
_____
