1 members (texczech), 51 guests, and 2 robots.
Topics128,024
Posts1,055,395
Members48,422
#826838 02/16/2012 4:32 PM
I tried to remove the screw end of a drag link with a flat blade screwdriver....It kept slipping out of the slot. Reading the repair manual it specifies a special tool for that. What can I use to remove these ends????
A drag link socket. No kidding! You can get one at your FLAPS. It's a really big flat blade that goes on your socket drive. Get the biggest one that will fit, as those darn things can be stubborn.
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1949 GMC Panel Truck
1926 Model TT Truck
I've used a chisel that fit into the slot and used a wrench to turn it. Had to warm/heat a few of them to get it out.
1939 Chevrolet Stake Truck
....and if you still can't get it find a washer that fits the slot pretty tight and then weld it in...then twist out with wrench! (Pete,that's a good idea)
