| | | Forums66 Topics128,135 Posts1,056,418 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2010 Posts: 62 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2010 Posts: 62 | whats the diferance betwean 205/75/15 and 215/70 /15 on 1950 1/2 ton not halling weight.thanks
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | The 205 refers to tread width in millimeters. The 75 refers to side wall height, 75% of tread width. So the 215/70 will be a little bit taller. | | | | | Joined: May 2008 Posts: 49 Wrench Fetcher | | Wrench Fetcher Joined: May 2008 Posts: 49 | | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | I am not sure what you are looking for, but Les Schwab has 7.00-15 tires that are 29" and a bit tall. But you have to go the store and ask for them, as they are not on the website. They seem to be a very good tire. It is the only tire they have in that size so its hard to mix them up. And they look good on the old trucks.I posted a picture under (UPDATE 15" wheels) in general truck talk not too long ago, I would repost the picture but I don't know how. I looked back and the posting for the picture was 1-29-12, if you want to look at them.
| | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | I've got 215/85/16s Ironman tires on my 52-3100 and am very happy with them.
Pete
| | | | | Joined: Feb 2000 Posts: 5,223 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,223 |
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The 205 refers to tread width in millimeters. The 75 refers to side wall height, 75% of tread width. So the 215/70 will be a little bit taller. The 215/70 will be a little wider, not taller. The overall hight will be pretty close to the same, within a tenth of an inch or so.
Bill Burmeister | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | The 205 refers to tread width in millimeters. The 75 refers to side wall height, 75% of tread width. So the 215/70 will be a little bit taller. The 215/70 will be a little wider, not taller. The overall hight will be pretty close to the same, within a tenth of an inch or so.  the tire sizes are 205/75 which is 153.75 tall and 215/70 which is 150.50 tall, I get 3.25 mm difference, times two?, for a total of less than 1/2" difference between them for total height but the narrow tire would be the tallest. I hate the metric system!  | | | | | Joined: Sep 2011 Posts: 1,456 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,456 | Caution mounting too wde of tires on old 5 & 5 1/2 wheels. These will break over time if tire is too wide for wheel. Many tire sites will list (tirerack.com) desired wheel width for a given tire.
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 |  the tire sizes are 205/75 which is 153.75 tall and 215/70 which is 150.50 tall, I get 3.25 mm difference, times two?, for a total of less than 1/2" difference between them for total height but the narrow tire would be the tallest. I hate the metric system!  Converted to Standard, the 205/75 has an 8.1" dection width, and a 27.1" diameter. The 215/70 has an 8.5" section width, and a 26.9" diameter, so there's only .2" difference in hight, but .4" differnce in width, with, as you mention, the wider tire being shorter. That can even vary depanding on manufacturer and what model tire it is. The sizes are really a nominal size, with rim diameter being the only true constant. To get the actual dimensions, you really need to check the manufacturers specification.
