1 members (baldeagle),
53
0
Mod | | | Forums66 Topics128,003 Posts1,055,244 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 159 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 159 | I have read a lot of past discussions about installing headliners, but what I'm interested in is headliner finish.
I bought one of the aftermarket cardboard units, but I'm thinking of applying an old antique-looking map to it before installation. There was a post here wherein someone applied a collage of avocado box labels to their headliner - pretty cool.
Anyone care to post more pics of their "custom" headliner finishes?
It is neither wealth nor splendor, but tranquility in occupation which brings happiness. - Thomas Jefferson
CK
| | | | | Joined: Feb 2006 Posts: 549 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 549 | | | | | | Joined: Apr 2009 Posts: 159 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 159 | Nice! I notice the visors are covered in the same material - nice attention to detail!
Has anyone done any other type of application? Rod run stickers? posters? Just looking for ideas other than painted cardboard.
Craig
CK
| | | | | Joined: Jun 2005 Posts: 422 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 422 | | | | | | Joined: Apr 2009 Posts: 159 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 159 | AD_Pickup - looks good! Did you glue the (vinyl?) to a cardboard headliner from a vendor, or did you start from scratch? My '50 has a middle bow. . .how did you get rid of that?
CK
| | | | | Joined: Jun 2005 Posts: 422 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 422 | No cardboard behind the liner, the middle bow is above the headliner. The headliner attaches to the bow by loops sewed into the seam. | | | | | Joined: Apr 2009 Posts: 159 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 159 | 327 views later, it looks like folks are interested in headliners. . . If you don't have pictures, how about sounding off with ideas you have for your headliners? Old newsprint ads? Burlap? Turkey feathers?  Keep the ideas coming! Craig
CK
| | | | | Joined: Apr 2011 Posts: 89 'Bolter | | 'Bolter Joined: Apr 2011 Posts: 89 | My plan (almost there) is to use thin cedar slats/veneer about 3in wide and run it in strips across the width of the ceiling after I lay my padding down. The wood in the headliner will be matched with cedar shingle sunvisors and cedar door panel trim.
Cedar is wonderful.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yes Chooglin, cedar is great wood, but -from someone who has used lots of it for years- I'd advise that you make sure the cedar you use gets very well sealed all 6 sides and that you prepare and stash extra to replace pieces that split or warp with use and variations in ambient humidity  Bill | | | | | Joined: Jun 2008 Posts: 1,644 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 1,644 | When I bought my truck it had no door panels, so I thought I'd make my own after I saw the prices for new ones. The material I settled on was used political signs. You know, the ones made of corregated plastic? I found a really large one and after measuring where the missing panels used to be, I marked it out on the plastic with a felt tip pen and then cut them out with some heavy duty scissors. Then I sprayed 3M adhesive on them and covered them with vinyl that I had bought at a Hancock fabric store. They turned out great. I have plans to do the exact same thing for my headliner.
Just my 2 cents worth.
Chuck 1950 Chevy 1/2 ton (all original) 1951 Chevy 1/2 ton (future streetrod) 1941 Chevy coupe 1938 Chevy coupe streetrod | | | | | Joined: Apr 2009 Posts: 159 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 159 | Chooglin - be sure to post some pictures of the cedar when it's done! I like the wood idea because there are a lot of us that split our time and talents between woodwork and metalwork!
Spotbiltxo - FINALLY a something good comes out of politics! Did you add any designs to the vinyl?
How about using old movie posters or car dealership advertisements? Travel brochures? Pictures from the trips taken in the truck?
CK
| | | | | Joined: Jun 2008 Posts: 1,644 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 1,644 | chevoldsmoyota, Never thought of it that way, but I agree. I'm glad I could find something good I could use associated with politics!!
No sir, I did not put any designs in the vinyl. I'm not that talented. The vinyl did have a subtle pebble pattern in it, so that looks nice as is.
Thanks.
Chuck 1950 Chevy 1/2 ton (all original) 1951 Chevy 1/2 ton (future streetrod) 1941 Chevy coupe 1938 Chevy coupe streetrod | | | | | Joined: Sep 2006 Posts: 335 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 335 | http://www.flickr.com/photos/9155420@N02/sets/72157629416875247/ | | | | | Joined: May 2010 Posts: 303 Shop Shark | | Shop Shark Joined: May 2010 Posts: 303 | AD PICKUP
great job on your headliner. I have a question though you might be able to answer. I picked up a headliner froom Brothers truck parts. The front of the headliner was wider and went about 3 inches further back then my center headliner bow would go. And the back piece was about 3 inches to short. Is there a differnce between a 5 window cab headliner and a 3 window cab headliner? Also what kind of insulation did you use between your headliner and top of your cab if any? thanks | | | | | Joined: Jun 2005 Posts: 422 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 422 | No difference in 5 window and 3 window headliner. I used aircraft insulation in mine. A upholsterer friend of mine suggested and got it for me. | | | | | Joined: May 2010 Posts: 303 Shop Shark | | Shop Shark Joined: May 2010 Posts: 303 | thanks for the info and the reply | | |
