3 members (Paul_WNC, thekid1950, TUTS 59), 23 guests, and 5 robots.
Topics128,012
Posts1,055,320
Members48,419
#822531 02/03/2012 3:11 PM
I have read a lot of past discussions about installing headliners, but what I'm interested in is headliner finish.
I bought one of the aftermarket cardboard units, but I'm thinking of applying an old antique-looking map to it before installation. There was a post here wherein someone applied a collage of avocado box labels to their headliner - pretty cool.
Anyone care to post more pics of their "custom" headliner finishes?
It is neither wealth nor splendor, but tranquility in occupation which brings happiness. - Thomas Jefferson
CK
chevoldsmoyota #823327 02/05/2012 11:11 PM
Avette4me #823696 02/07/2012 2:56 AM
Nice! I notice the visors are covered in the same material - nice attention to detail!
Has anyone done any other type of application? Rod run stickers? posters? Just looking for ideas other than painted cardboard.
Craig
CK
chevoldsmoyota #823718 02/07/2012 3:47 AM
AD_Pickup #823747 02/07/2012 4:52 AM
AD_Pickup - looks good! Did you glue the (vinyl?) to a cardboard headliner from a vendor, or did you start from scratch? My '50 has a middle bow. . .how did you get rid of that?
CK
chevoldsmoyota #823918 02/07/2012 9:49 PM
No cardboard behind the liner, the middle bow is above the headliner. The headliner attaches to the bow by loops sewed into the seam.
AD_Pickup #826059 02/14/2012 4:37 AM
327 views later, it looks like folks are interested in headliners. . .
If you don't have pictures, how about sounding off with ideas you have for your headliners?
Old newsprint ads? Burlap? Turkey feathers? dang Keep the ideas coming!
Craig
CK
chevoldsmoyota #826166 02/14/2012 4:20 PM
My plan (almost there) is to use thin cedar slats/veneer about 3in wide and run it in strips across the width of the ceiling after I lay my padding down.
The wood in the headliner will be matched with cedar shingle sunvisors and cedar door panel trim.
Cedar is wonderful.
1954 3600
[/url] www.tors54.tumblr.com
Chooglin #826182 02/14/2012 5:42 PM
yes Chooglin, cedar is great wood, but -from someone who has used lots of it for years- I'd advise that you make sure the cedar you use gets very well sealed all 6 sides and that you prepare and stash extra to replace pieces that split or warp with use and variations in ambient humidity wink
Flxible #826756 02/16/2012 6:26 AM
When I bought my truck it had no door panels, so I thought I'd make my own after I saw the prices for new ones. The material I settled on was used political signs. You know, the ones made of corregated plastic? I found a really large one and after measuring where the missing panels used to be, I marked it out on the plastic with a felt tip pen and then cut them out with some heavy duty scissors. Then I sprayed 3M adhesive on them and covered them with vinyl that I had bought at a Hancock fabric store. They turned out great. I have plans to do the exact same thing for my headliner.
Just my 2 cents worth.
Chuck
1941 Chevy coupe
1938 Chevy coupe streetrod
Spotbiltxo #826812 02/16/2012 3:10 PM
Chooglin - be sure to post some pictures of the cedar when it's done! I like the wood idea because there are a lot of us that split our time and talents between woodwork and metalwork!
Spotbiltxo - FINALLY a something good comes out of politics! Did you add any designs to the vinyl?
How about using old movie posters or car dealership advertisements? Travel brochures? Pictures from the trips taken in the truck?
CK
chevoldsmoyota #827155 02/17/2012 3:48 PM
chevoldsmoyota, Never thought of it that way, but I agree. I'm glad I could find something good I could use associated with politics!!
No sir, I did not put any designs in the vinyl. I'm not that talented. The vinyl did have a subtle pebble pattern in it, so that looks nice as is.
Thanks.
Chuck
1941 Chevy coupe
chevoldsmoyota #828449 02/21/2012 3:46 PM
http://www.flickr.com/photos/9155420@N02/sets/72157629416875247/
Spotbiltxo #831665 03/03/2012 12:03 AM
AD PICKUP
great job on your headliner. I have a question though you might be able to answer. I picked up a headliner froom Brothers truck parts. The front of the headliner was wider and went about 3 inches further back then my center headliner bow would go. And the back piece was about 3 inches to short. Is there a differnce between a 5 window cab headliner and a 3 window cab headliner? Also what kind of insulation did you use between your headliner and top of your cab if any? thanks
tracern1 #832205 03/05/2012 12:03 AM
No difference in 5 window and 3 window headliner. I used aircraft insulation in mine. A upholsterer friend of mine suggested and got it for me.
AD_Pickup #832218 03/05/2012 12:58 AM
thanks for the info and the reply
Moderated by  ndkid275, Phak1
