7 members (55shaker, Tim Canfield, moparguy, Hotrod Lincoln, Gdads51, Bill Hanlon, treegrower),
132
0
Mod | | | Forums66 Topics128,195 Posts1,057,380 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2012 Posts: 61 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2012 Posts: 61 | Hi all! I'm Tom, from Northern California. I'm eyeing a '39 1 1/2 ton, PTO, dump bed. I took a look last week, it runs, seems complete, I'm told everything works. It needs tires.. I printed frame specs for a crawl-under, was told to carefully inspect the bolts for excessive corrosion, since it was from a dairy ranch. I appear to be the 3rd, or fourth owner. Anything else I should watch for?? Great info! My brother, who I helped get a '55 Suburban for recommended you guys. Tom | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | Welcome to the 'Bolt  Try posting this question in the Big Bolt section. Lot's of knowledgeable guys go there daily. | | | | | Joined: Oct 2010 Posts: 111 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 111 | Hi from Indiana. As mentioned check out the big bolts section. You'll make a lot of friends there.
Ken | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | abxtc, welcome to the stovebolt. Its a good feeling to know you can save a piece of American history. Go for it. | | | | | Joined: Mar 2007 Posts: 4,217 Moderator | | Moderator Joined: Mar 2007 Posts: 4,217 | Welcome Tom, hope this truck pans out for you. There's lots of help available should you get this truck.
Leo | | | | | Joined: Feb 2012 Posts: 61 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2012 Posts: 61 | I used the site to verify some info, and made my down payment. The owner also has a '40 rod, and rebuilding a '68 P/U, so that gave me hope!
