| | | Forums66 Topics128,162 Posts1,056,938 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2011 Posts: 99 Shop Shark | | Shop Shark Joined: Dec 2011 Posts: 99 | I took the ole 3100 1/2T with original 216 and 3 on the tree out today. Reverse, 1st and 3rd shifted OK. Shifting in 2nd with clutch engaged produced tremendous GRINDING regardless of how many times and what speed I tried to engage this gear.
Does this mean it was getting stuck in the gearbox or at the linkages etc? It worked fine a few weeks ago, but I had to go back and fix the recent engine electrical / ignition problems.
I could shift in 1st easily, then bypass 2nd into 3rd and let her get up to speed without a problem, but shifting into 2nd with any momentum would cause a GRIND strange. I was doing to H-shaped shift pattern to ensure that I was enaging it cleanly.
Any ideas?????
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I wonder if your clutch is not fully releasing? How much play do you have at the top of the pedal travel? | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Bad syncro from all that speed shifting????
Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | The synchros were the weakest point of those transmission. I would suspect you will have to drive it the way it is or rebuild the transmission. A little grinding really doesn't hurt anything. When they start jumping out of gear its high time to rebuild them. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | double clutch when you go into 2nd either up or down and live with it
Bill | | | | | Joined: Dec 2011 Posts: 99 Shop Shark | | Shop Shark Joined: Dec 2011 Posts: 99 | Well, not planning on living with it. That is not exactly an option. Seems to have fixed itself. Took truck again and now it shifts into all gears OK now. I think it just needs more use. Still nervous driving the truck on busy roads but guess I will get used to it soon.
Thanks for the advice... | | |
