1 members (MickeyP),
110
Mod | | | Forums66 Topics128,193 Posts1,057,253 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#82547 09/04/2007 11:46 PM | Joined: Aug 2007 Posts: 8 Junior Member | | Junior Member Joined: Aug 2007 Posts: 8 | Howdy all,
I have found only one post regarding Porta-Walls. They are a wide white wall that is held between the tire and rim. Has anyone had any experience with these? I use my truck mostly on back roads and rarely exceed 50-60 mph. So I figure they might hold up under the limited use and low speed.
Panhead60 | | |
#82548 09/05/2007 12:15 AM | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Look at my truck in the gallery. I had them on it for years with bias-ply tires. Never had problems with them at all except they finally got brittle and fell apart. The one thing you do want to watch is rubbing curbs as it will rip them badly. If you like the looks of them go ahead and put them on. I liked mine but I now prefer the black wall look. Bill | | |
#82549 09/05/2007 12:18 AM | Joined: Aug 2005 Posts: 6,378 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,378 | I don't have any personal experience using them. I have a couple of buddys who sell them along with other hotrod & custom dress up parts. If you want to talk with them call 620-442-8500 (9 to 5 central time) & ask for Lee or Kirby.
#82550 09/05/2007 12:39 AM | Joined: Feb 2004 Posts: 29,878 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,878 | Making a tubeless tire hold air with one of those things sandwiched between the tire and the rim will be fun, and getting a good wheel balance is just about a lost cause. I spent lots of years repairing tires with them installed back in the early 60's. I learned a lot of brand new vocabulary words! Jerry
#82551 09/05/2007 1:05 AM | Joined: Aug 2007 Posts: 8 Junior Member | | Junior Member Joined: Aug 2007 Posts: 8 | Thanks Gents,
I have radials on the truck now and I thought I might save a grand in tires and such. As long as I am having the rims powder coated, I may as well go for the Cokers!!
Thanks again, Panhead | | |
#82552 09/05/2007 1:24 AM | Joined: Mar 2003 Posts: 1,132 Shop Shark | | Shop Shark Joined: Mar 2003 Posts: 1,132 | Porta Walls date back to the late 40s, maybe earlier. I had them on most of the 37/39/40 Fords that I owned as a kid. Never noticed or cared if they vibrated because with those old Fords you couldn't tell the difference. Looked cool though. Weeds | | |
#82553 09/05/2007 2:35 AM | Joined: Mar 2005 Posts: 684 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 684 | I bought a new Corvair Monza in 1961 with black tires and put Porta walls on it, the car shimmed something terrible. Had to take them off. | | |
#82554 09/05/2007 2:55 AM | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | Last summer I found one made of steel, anyone ever seen one of these?? | | |
#82555 09/05/2007 5:28 AM | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | I guess there are pros and cons. I used tubes in my tires and as mentioned above they worked fine until they finally rotted away after about 8-10 years in use. | | |
#82556 09/05/2007 5:51 AM | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | I've got them on my truck. The trick with radials is to use a thinner whitewall (I think mine are 2 1/2") to keep the porta-wall above the "pooch line" (my term for the bulge on the sidewall). No problems so far. | | |
#82557 09/07/2007 6:16 AM | Joined: Sep 2007 Posts: 19 New Guy | | New Guy Joined: Sep 2007 Posts: 19 | My Chevy came with those on it and they look terrible. The fellow that I bought the truck off of said that they were not what he had expected. They ripple and sag off the tire. Perhaps some kind of adhesive would help. Thats just my experience but maybe different brands of these are more successful than others. Cool concept!
Elwardo
#82558 09/07/2007 12:26 PM | Joined: Aug 2006 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2006 Posts: 37 | I had them on a '52 chev and a '57 chev back in the mid 60s. They were on tube type tires and seemed to work ok. Don
"Sometimes my luck is so bad that if I bought a pumkin farm, halloween would probobly be outlawed."
#82559 09/07/2007 1:54 PM | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | Part of my weekly routine as a teen age driver back in the late 50's, was to wash and wax our beloved cars.....also jack up each wheel, let out the air, and with your thumbs, press the Porta-walls back in under the edge of the rim until the little ridges would "catch". If you had a fast car and were a little more aggressive with your driving style, you might have to make a mid-week adjustment.
I started my road life in a 46 Jeep wagon and Pop could monitor my driving habits by a quick visual check!!!! Being top-heavy, the wagon was quick to "spit" out the soft rubber bead....not all the way out, but just enough so there was a noticeable bulge at the rimline.....never gave it a thought that his concern was over safety issues and not just trying to restrict my driving "fun"! Getting my first set of "hand-me-down" REAL whitewalls was like winning the lottery. Great memories from a great time!!!!
Dave | | |
#82560 09/07/2007 5:55 PM | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Gluing them on does not work. I sold a set to a fellow who tried to glue them to the tires on his T-Bucket but they did not last. | | |
#82562 09/14/2007 12:55 AM | Joined: Aug 2007 Posts: 8 Junior Member | | Junior Member Joined: Aug 2007 Posts: 8 | HMMMMMMMMMmmmmmmmmmmmmmmmmmmmmmm!!??
Something else to consider | | |
