1 members (Hotrod Lincoln), 104 guests, and 2 robots.
Topics128,089
Posts1,056,004
Members48,430
#825242 02/12/2012 12:05 AM
Do i need to remove the fan blade and pulley off the water pump to take it off?
1954 248 GMC motor.
not necessary, but if you have the rad still in place, it's a good idea, even if a little awkward
It might come off with the fan on but you'll risk boogering up your radiator.
I don't know about a 54, but my 55 had the pulley pressed on, never could get it off.
1955 Second Series GMC
"Done - A 50 Year Journey"
Follow in the DITY
-- No one said it was going to be easy
rbs56 #825342 02/12/2012 4:09 AM
I don't know about a GMC motor but I believe with the Chev motors pre 1955, did not have an impeller that goes into the block. The point is that with the bolts out, the whole assembly can be slid off. When I did mine I removed the rad but I have read about people doing it with the rad in place.
1951 1 Ton Completed
GMC pumps are just like 1954 and earlier Chev pumps in design, no impeller sticking out the back.
You can put a thin piece of card board against the radiator to protect it and remove pump and fan as an assembly.
My Blog
Thanks all, will attempt this feat today and let you know.After the comments about boogering up the radiator i think i will pull the fan first just as a precaution.
Wes
