0 members (),
93
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,055 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2012 Posts: 15 New Guy | | New Guy Joined: Feb 2012 Posts: 15 | Do i need to remove the fan blade and pulley off the water pump to take it off?
1954 248 GMC motor. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | not necessary, but if you have the rad still in place, it's a good idea, even if a little awkward
Bill | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | It might come off with the fan on but you'll risk boogering up your radiator. | | | | | Joined: Sep 2011 Posts: 116 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 116 | I don't know about a 54, but my 55 had the pulley pressed on, never could get it off. 1955 Second Series GMC"Done - A 50 Year Journey"Follow in the DITY-- No one said it was going to be easy
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I don't know about a GMC motor but I believe with the Chev motors pre 1955, did not have an impeller that goes into the block. The point is that with the bolts out, the whole assembly can be slid off. When I did mine I removed the rad but I have read about people doing it with the rad in place. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | GMC pumps are just like 1954 and earlier Chev pumps in design, no impeller sticking out the back. You can put a thin piece of card board against the radiator to protect it and remove pump and fan as an assembly.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Feb 2012 Posts: 15 New Guy | | New Guy Joined: Feb 2012 Posts: 15 | Thanks all, will attempt this feat today and let you know.After the comments about boogering up the radiator i think i will pull the fan first just as a precaution.
Wes | | |
