1 members (Otto Skorzeny),
60
Mod | | | Forums66 Topics128,126 Posts1,056,354 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2010 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 66 | Well i broke down and spent some dough on a nice Offy polished valve cover this past week. Now i need to know what else do i need for install, it came w/ the stud kit but do i need some kind of seals in the top two holes where the studs run through? I've got a new cover gasket and new acorn nuts for the studs too. This is going on our 1959 Chev apache truck, it has a 261 w/ a 235 head. I've also read that sometime a clearance issue w/ the thermostat housing can cause issues so i have a spacer ready if needed to bring the housing out and away from the cover if needed. Thanks for any information from any one that has been down this road.  | | | | | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | Tobin
The studs replace the existing bolts on the rocker assembly. Remove bolts one at a time, torque the studs down per your shop manual then intall the fine valve cover!
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: May 2010 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 66 | I've got the stud thing figured out, i'm curious about the holes coming throught the top of cover....do these require a "seal"? Info appreciated big time!!
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | These grommets might work. If in doubt, call them - they also sell the Offy valve cover. | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Here is a picture of the studs in place. valve cover studs I have a Wayne valve cover and it came with the rubber grommets Tim posted a link to.I would think the offenhauser would use them as well. Tim Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | I've got a new cover gasket Look in the box the gasket came in, if it a felpro there might be 2 grommets in it. the cover gasket for my 235 came with them felpro FEL-PRO Part # VS50189C | | | | | Joined: Aug 2001 Posts: 1,299 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 1,299 | I bought the offenhouser valve cover in the late 70 straight from Offy. It came with the same stud kit and the "seals" that they sent were nothing more than cut off sections of a runner fuel line that went over the studs and fit fairly tight in the holes of valve cover. It did come with the instructions there may be a clearance issue with the thermostat housing and they suggested using an extra gasket if needed. | | | | | Joined: May 2010 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 66 | Thanks DADS50....the grommets were in with the gasket(Felpro)and i'm in business!! I think this cover will really dress up the engine. | | | | | Joined: Jun 2011 Posts: 420 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 420 | if im not mistaken, isnt the 216 engine the one with the 2 studs in the top and the 235 has the valve cover bolts around it? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | if im not mistaken, isnt the 216 engine the one with the 2 studs in the top and the 235 has the valve cover bolts around it? All 216 engines and all 235 engines through 1953 used the 2-bolt valve covers. And, it is quite easy to adapt the later 235 heads (and all 261 heads) to work with the two-bolt valve cover: adapter kit. | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | The photo I linked to above is of my 1954 261 engine.I used the stud kit so I could use the Wayne valve cover.I could even use a 216 valve cover if I want to.
