2 members (baldeagle, dunfire),
86
Mod | | | Forums66 Topics128,037 Posts1,055,467 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2012 Posts: 73 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2012 Posts: 73 | Hey:
Can anyone tell me how I can get the best MPG out of a 235 with a 3 speed transmission and 3.9 rear end?
Thanks!
Glen | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | don't haul loads, don't accelerate hard, stay under 40  Bill | | | | | Joined: Aug 2008 Posts: 403 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 403 | I can agree with Red 58 on that but make sure you have good plugs,wires,points and condenser,clean oil in the carb filter if oil bath, or replace the paper filter last but not least a good carb rebuild and proper inflated tires will help in achiving good fuel mileage. 62Blue Don
62Blue 62Chevy in progress You've never been lost until you've been lost at Mach3" Paul F Crichmore (Test Pilot)
| | | | | Joined: Sep 2011 Posts: 1,451 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,451 | Agree with Red. Mine does the best on the gravel freeways.
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | make sure that you have a decent motor to start with eg; compression. you may want to move to a little higher r/axle ratio; in the 3:4-3:7 range or perhaps a little taller tire ron | | | | | Joined: Feb 2012 Posts: 73 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2012 Posts: 73 | Thanks guys. I'm guessing my gut instinct was right - it kinda sucks for mileage. Perhaps a better question should have been, "What should I actually expect for mileage?"
Glen | | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | Yes but other than the suggestions from the others, you would have to sway from stock and spend some $$$ with a good free flowing exhaust and maybe an after market electronic fuel injection and ignition systems. With those three items together you could pick up as much as 4 to 6 more MPG. However the cost would be high about $3500 to $5000 to do all three. Along with the increased MPG would come the benefits of more power and better drivability the extra power would allow the use of taller gearing where you could possibly find another couple MPG for another $400 $500 of course. The first thing to do is to ensure that the base engine is in good condition, no loss of compression no carbon build up exc. Then ensure that it is in the best state of tune possible, plugs wires timing exc. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | if you get 12+ mpg city you'll be doing OK, don't expect more than 15 without non-trivial upgrades
Bill | | | | | Joined: Jan 2007 Posts: 446 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 446 | Red, are you sure about your data? I get decent MPG from my 235. Last time I checked when on a road trip I averaged 18 MPG and this included some mountain climbing. Now, I will say that was with a different carb. before it failed on me. The NAPA rebuilt carb get's worse MPG. I ended up rebuilding that one again myself with no improvement in MPG, but it does run good and strong.
Now you have me thinking Red.......I wonder if the jets in the old carb were smaller, or something else was different to increase the MPG. Something for me to investigate... | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The carb, timing, & vacuum advance all need to work good to get the best MPG. The only way to increase it if you are doing highway driving is a higher gear ratio. The engine is just turning too fast with the 3.90 gears to get respectable mileage. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Jeff - I did say 'city'- there's always some variation due to the way a person drives of course, and as George points out, there will be variation in the state of tune, even of the same engine over time .... but I'd be very surprised if anyone really gets an accurate 18 average at highway speeds with 3.90's unless it's mostly downhill
Bill | | | | | Joined: Jan 2007 Posts: 446 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 446 | Red, I did notice a big increase in power after I rebuilt the carb, and this was after the road trip when I got 18 MPG. Perhaps I had a fuel restriction and that caused the good milage. I do admit I don't get that kind of milage now after the carb rebuild and tune up. I haven't check the fuel MPG since the carb rebuild either but it seems to suck more gas then it did before. | | | | | Joined: Apr 2009 Posts: 108 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 108 | My last 325/three speed/3.9's was in a '57 3200. 17 MPG City or Freeway on leaded regular. That truck was comfortable at 55 MPH on the freeway. | | | | | Joined: Feb 2012 Posts: 73 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2012 Posts: 73 | Thanks again guys. Anyone tried switching the Rochester carb for something else? Maybe a 1bbl Carter? I've heard the old Rochesters weren't the most efficient. | | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | My experience is a one barrel carb gets miserable MPG. That was in a '70 Nova with a factory GM Monojet on a 230 I6. Great little carb., just not great mileage.
I got better mileage with a 1977 305 with a factory 2 barrel.
