3 members (RLB, qside, Gray_Ghost), 71 guests, and 1 robot.
Topics128,072
Posts1,055,907
Members48,429
#822867 02/04/2012 4:24 PM
I have a 49 1/2 ton with tube shocks. When I look around for replacement shocks all I find is shocks down to 1950. Can I assume that these shocks will fit my 49 or do i need to take mine off and carry them with me to find something that will work.
red49 #822882 02/04/2012 5:24 PM
Stock, I believe 1949 was the last year of lever shocks. You might just want to bring what you've got to the FLAPS.
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1949 GMC Panel Truck
1926 Model TT Truck
Mr. Lang #825375 02/12/2012 5:41 AM
In fact, 49 was last year for lever shocks. Tube came on 50.
red49 #825428 02/12/2012 2:42 PM
There are and have been kits to convert the lever action shocks to the aircraft type for some time. I guess yours have been converted. I would have to think the best shocks for your truck would be the 1950 and later shocks. Presumably the mounts are in the right place, and if they are, I would not hesitate to put those 1950 and later shocks on.
Kurt
If you have a 1949 with tube shocks, there are three reasons: someone converted to tube shocks from knee action shocks or you have a 1950 or newer frame and finally you don't have a 1949 at all, but a 1950 or newer. Knee action shocks were standard on 1947-1950 chevrolet trucks and 1947-1951? GMC trucks
You may have to remove your shock and take it in the auto store to get the exact replacement.
GMONIZ #826405 02/15/2012 1:16 PM
I believe that should read 1947-1949 Chevy trucks as the 1950's did have tube shocks as you noted earlier.
DG
Denny G
Sandwich, IL
