9 members (48jim1ton, Gdads51, Forty9, Hotrod Lincoln, gswbbc, frogfarmer, Wayne67vert, sron48, dt235sd),
75
0
Mod | | | Forums66 Topics128,043 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2009 Posts: 163 Shop Shark | | Shop Shark Joined: Aug 2009 Posts: 163 | I installed a new wire harness in my '47 and a new sending unit thanks to my nephew for stepping on my old one. I keep a gas can in the bed of the truck because I cant get the gauge to work. I installed the wire harness according to the instructions. Does anyone have some idea what I might have missed? Or a way to check the gauge to see if it works? Still 6 volt system | | | | | Joined: Aug 2009 Posts: 163 Shop Shark | | Shop Shark Joined: Aug 2009 Posts: 163 | There is continuity at the gauge. My power wire was off the switch, but when I connect it and the key is off, the switch is hot cause the gauge still reads that there is gas in the tank.
I am going to run a jumper wire from the gas gauge to the amp gauge to get power I guess until I figure out why the wire that connects at the switch stays hot with the key off. | | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | So, the gauge works now? But stays on all the time? You'll have to check the wiring diagram, but I believe the fuel gauge gets it's power from the switched lead on the ign switch- it gets connected to the same terminal that runs out to the coil.
The ammeter is always hot.
Perhaps double check the connections on the back of the ign switch. | | |
