2 members (NJC, baldeagle), 33 guests, and 3 robots.
Topics128,014
Posts1,055,327
Members48,419
#825190 02/11/2012 8:47 PM
I installed a new wire harness in my '47 and a new sending unit thanks to my nephew for stepping on my old one. I keep a gas can in the bed of the truck because I cant get the gauge to work. I installed the wire harness according to the instructions. Does anyone have some idea what I might have missed? Or a way to check the gauge to see if it works? Still 6 volt system
There is continuity at the gauge. My power wire was off the switch, but when I connect it and the key is off, the switch is hot cause the gauge still reads that there is gas in the tank.
I am going to run a jumper wire from the gas gauge to the amp gauge to get power I guess until I figure out why the wire that connects at the switch stays hot with the key off.
So, the gauge works now? But stays on all the time? You'll have to check the wiring diagram, but I believe the fuel gauge gets it's power from the switched lead on the ign switch- it gets connected to the same terminal that runs out to the coil.
The ammeter is always hot.
Perhaps double check the connections on the back of the ign switch.
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1949 GMC Panel Truck
1926 Model TT Truck
