2 members (Hotrod Lincoln, klhansen), 119 guests, and 2 robots.
Topics128,127
Posts1,056,357
Members48,441
#824365 02/09/2012 5:04 AM
Can anybody help with rust removal on the inside of the cab on my 47 loadmaster
green_truck, do you have some pics so that we may see the extent of your rust problem ?
I used wire wheels attached to a drill to get most of the rust... I did not have the $$$ or access to a sand blaster... Hard to get place like under the dash I used wire brush and steel wool...
Here is what mine looked like,
Interior Restore 2009
Interior 2010
Dash
1954 Chevy 3104 3 Window Hydra-Matic in my family for over 60 Years
Once in a while you get shown the light in the strangest of places if you look at it right... "Scarlet Begonias" Grateful Dead 1974
For under the dash I found one of the those flexible drives for the drill pretty handy.
1951 1 Ton Completed
When using a wire or disc abrasive it's best not to use a high speed grinder for this process. They can generate enough heat to warp the metal if held in one spot too long. A slower orbital sander would be better to use.
Drew
DrewP #824692 02/10/2012 5:47 AM
Anything quicker than a wire wheel
I don't have any pics yet the rust is not very bad but I want to clean it good before I paint
Look for a shop that specializes in dipping your body into a tank of solution that removes all the Rust,Paint and grime. The cab must be completly striped of all the inside and outside parts switches, gauges,door handles, window frames etc..
The cab will come out really clean to bare metal and will have all the Rust Body filler or visiual holes from where the rust used to be if there is any. Then you can coat it with a rust preventive material until you get to the body work if need be.
62Blue
Don
62Blue
62Chevy in progress
You've never been lost until you've been lost at Mach3" Paul F Crichmore (Test Pilot)
Don G. #824882 02/10/2012 9:48 PM
Big Bolt Forum Co-moderator
Don G.
When you say rust preventative material, are you talking about shooting some primer on it, or some other coating? Would it be something like Rust Mort? I have only had experience with small parts and clean and paint generally the same day.
1948 Chevy 2-Ton
Super55 #824946 02/11/2012 12:54 AM
green truck, Just so happens that the current issue of Vintage Truck magazine has an informative article on rust removal you may like to read. The mag is available at Barnes and Noble among other book stores.
Drew
DrewP #824983 02/11/2012 3:09 AM
Thanks for the info I will check it out.
Healingbear- What colors did you use inside the cab?
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
Here you can see how mine was I stripped the whole thing with 3M discs and the flexible nylon type (orange) sold at HF. They all fit in a 1/4" drill and keeps the heat down so nothing warps.
http://good-times.webshots.com/photo/2209170800102454676oBwnSu
http://good-times.webshots.com/photo/2530357230102454676ZbijuO
