| | | Forums66 Topics128,130 Posts1,056,367 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2012 Posts: 5 New Guy | | New Guy Joined: Jan 2012 Posts: 5 | Can anybody help with rust removal on the inside of the cab on my 47 loadmaster | | | | | Joined: Sep 2009 Posts: 433 'Bolter | | 'Bolter Joined: Sep 2009 Posts: 433 | green_truck, do you have some pics so that we may see the extent of your rust problem ? I used wire wheels attached to a drill to get most of the rust... I did not have the $$$ or access to a sand blaster... Hard to get place like under the dash I used wire brush and steel wool... Here is what mine looked like, Interior Restore 2009 Interior 2010 Dash
1954 Chevy 3104 3 Window Hydra-Matic in my family for over 60 Years
Once in a while you get shown the light in the strangest of places if you look at it right... "Scarlet Begonias" Grateful Dead 1974
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | For under the dash I found one of the those flexible drives for the drill pretty handy. | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | When using a wire or disc abrasive it's best not to use a high speed grinder for this process. They can generate enough heat to warp the metal if held in one spot too long. A slower orbital sander would be better to use.
Drew
| | | | | Joined: Jan 2012 Posts: 5 New Guy | | New Guy Joined: Jan 2012 Posts: 5 | Anything quicker than a wire wheel | | | | | Joined: Jan 2012 Posts: 5 New Guy | | New Guy Joined: Jan 2012 Posts: 5 | I don't have any pics yet the rust is not very bad but I want to clean it good before I paint | | | | | Joined: Aug 2008 Posts: 403 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 403 | Look for a shop that specializes in dipping your body into a tank of solution that removes all the Rust,Paint and grime. The cab must be completly striped of all the inside and outside parts switches, gauges,door handles, window frames etc.. The cab will come out really clean to bare metal and will have all the Rust Body filler or visiual holes from where the rust used to be if there is any. Then you can coat it with a rust preventive material until you get to the body work if need be. 62Blue Don
62Blue 62Chevy in progress You've never been lost until you've been lost at Mach3" Paul F Crichmore (Test Pilot)
| | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | Don G. When you say rust preventative material, are you talking about shooting some primer on it, or some other coating? Would it be something like Rust Mort? I have only had experience with small parts and clean and paint generally the same day.
A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | green truck, Just so happens that the current issue of Vintage Truck magazine has an informative article on rust removal you may like to read. The mag is available at Barnes and Noble among other book stores.
Drew
| | | | | Joined: Jan 2012 Posts: 5 New Guy | | New Guy Joined: Jan 2012 Posts: 5 | Thanks for the info I will check it out. | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | Healingbear- What colors did you use inside the cab?
