5 members (2-Ton, Peggy M, Bill Hanlon, Woodcmiami, 1 invisible), 164 guests, and 2 robots.
Topics128,167
Posts1,057,015
Members48,458
Hi Fellow Bolters! I just read a thread from another website,from a guy that is thinking about adding an aftermarket oil-filter to his 235. I had that same idea,when I first purchased my '55 2nd Series 6500. The answer that I received from my mechanic was:"DEFINITELY NOT!!" Our trucks were designed to operate efficiently with regular oil- change intervals. Adding an aftermarket filter only filters about 10%,anyway, plus you have to drill holes in a perfectly good block to do so. If you don't remove all of the shavings, it would cause pre-mature engine wear/failure,which would be the reason for adding a filter in the first place! PLEASE...Don't fix what ain't broke!
Mo' Tater
You are referring to two types of filters.
The optional/accessory by-pass canister oil filter will filter about 10% of the flow, the other 90% does not get filtered. Over time, all the oil gets filtered. This works quite well.
http://www.stovebolt.com/techtips/engines/oil%20filters/index.html
The block can be modified for a full-flow filter - that is the one that might cause wear if the shavings are not cleaned out. People who have done this seem to be able to clean out the shavings.
http://www.stovebolt.com/techtips/full_pressure.htm
The by-pass filter is my choice.
There's no need to drill any holes to add a filter to the 216/235/261. The factory optional filter connects using existing ports in the block, T-ing off the guage fitting at the rear, and returning at a port near the center of the block. Any filtration will extend the life of your engine.
Bill Burmeister
Mine is a 1950's InnerLine aftermarket block mounted by-pass filter. It mounts where the oil distributor plate is located.
The InnerLine filter only works on low-pressure 216/235 engines. One advantage of this type of filter is that it needs no hoses.
The 55-2nd series engine referred-to in the first post has no oil distributor. Nonetheless, a by-pass canister filter will work with any year 216/235 and 54-57 261 engines.
Absolutely nothing wrong with doing a full flow oil filter conversion; drilling and tapping as necessary.
Also nothing wrong with the original type bypass filter.
If I were building an engine I'd for sure convert to full flow oil filter while I was at it.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
Thanks,guys! I appreciate the input. I will definitely install a full-flow oil filter BEFORE starting the truck this Spring! Thanks,again!-Bill Hickey
Mo' Tater
