2 members (Biermann, papas52),
154
Mod | | | Forums66 Topics128,164 Posts1,056,975 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2010 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 1,159 | Hi Fellow Bolters! I just read a thread from another website,from a guy that is thinking about adding an aftermarket oil-filter to his 235. I had that same idea,when I first purchased my '55 2nd Series 6500. The answer that I received from my mechanic was:"DEFINITELY NOT!!" Our trucks were designed to operate efficiently with regular oil- change intervals. Adding an aftermarket filter only filters about 10%,anyway, plus you have to drill holes in a perfectly good block to do so. If you don't remove all of the shavings, it would cause pre-mature engine wear/failure,which would be the reason for adding a filter in the first place! PLEASE...Don't fix what ain't broke! | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | You are referring to two types of filters. The optional/accessory by-pass canister oil filter will filter about 10% of the flow, the other 90% does not get filtered. Over time, all the oil gets filtered. This works quite well. http://www.stovebolt.com/techtips/engines/oil%20filters/index.htmlThe block can be modified for a full-flow filter - that is the one that might cause wear if the shavings are not cleaned out. People who have done this seem to be able to clean out the shavings. http://www.stovebolt.com/techtips/full_pressure.htmThe by-pass filter is my choice. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | There's no need to drill any holes to add a filter to the 216/235/261. The factory optional filter connects using existing ports in the block, T-ing off the guage fitting at the rear, and returning at a port near the center of the block. Any filtration will extend the life of your engine.
Bill Burmeister | | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | Mine is a 1950's InnerLine aftermarket block mounted by-pass filter. It mounts where the oil distributor plate is located. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | The InnerLine filter only works on low-pressure 216/235 engines. One advantage of this type of filter is that it needs no hoses.
The 55-2nd series engine referred-to in the first post has no oil distributor. Nonetheless, a by-pass canister filter will work with any year 216/235 and 54-57 261 engines.
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Absolutely nothing wrong with doing a full flow oil filter conversion; drilling and tapping as necessary. Also nothing wrong with the original type bypass filter.
If I were building an engine I'd for sure convert to full flow oil filter while I was at it.
Grigg | | | | | Joined: Nov 2010 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 1,159 | Thanks,guys! I appreciate the input. I will definitely install a full-flow oil filter BEFORE starting the truck this Spring! Thanks,again!-Bill Hickey | | |
