1 members (carbking),
160
10
Mod | | | Forums66 Topics128,283 Posts1,058,519 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2011 Posts: 33 New Guy | | New Guy Joined: Dec 2011 Posts: 33 | I was backing out of the garage and noticed the smoke from under the hood (52 suburban)- the clear flexible oil pressure line snapped and started pumping oil onto the manifold - I lost about 1 1/2 quarts max. Can I run the truck if i just plug up the pressure hole at the bottom of the block until it is replaced? Are the copper replacement lines from 'chevys of the 40's' site any good? are there other replacements available? Lastly, any tips on getting the line off from behind the gauge? any help is appreciated here. Thanks | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | That kit for Chevs of the 40s should have all the parts you need. Just disconnect and remove the plastic line and connectors. | | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | For what it's worth I have always used the plastic line kit made specifically for oil pressure guages and have never had a problem. Good luck whichever way you go.
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | You should be able to get a replacement locally. | | | | | Joined: Dec 2011 Posts: 33 New Guy | | New Guy Joined: Dec 2011 Posts: 33 | Cletis- when you say locally, do you mean at pep boys or napa? | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | | | | | | Joined: Dec 2011 Posts: 33 New Guy | | New Guy Joined: Dec 2011 Posts: 33 | thank you for the replys so far - have you encountered any issues with kink or routing the lines through the fire wall? Any tip son getting the line screwed out of the guage behind the firewall? | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Use a small flare wrench 1/4" I think. | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | It can be easy to screw up the back of the guage if too much pressure on the fitting is needed to lossen it. Just take your time.
Drew
| | | | | Joined: Dec 2010 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2010 Posts: 37 | I just picked up a (copper tubing complete kit) replacement for mine at Auto Zone for $11.99.
Saving American history one rust bucket at a time. When they're gone, they're gone forever!
| | | | | Joined: Feb 2009 Posts: 12 New Guy | | New Guy Joined: Feb 2009 Posts: 12 | Just a thought: If there is enough of the plastic line left you can go to NAPA or another parts house and buy the compression sleeve. All you will need to do is re-attach the old line with the new sleeve. Good luck!
Joe Trav | | | | | Joined: Feb 2000 Posts: 5,269 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,269 | The plastic becomes brittle after a while, so just replace it or go with the copper line from NAPA or one of the venders on this site. The piece that fits the gauge is a compression fitting, you will need to replace it or open it back up to accept the new line. Look at the link to Classic Parts above, you will see the end of the brass fitting is a cone, this squeezes the copper line sealing it off. If yours is already clamped down on plastic line, it will be tough to get the new copper line in place. Its best to cut the old line at the gauge and back the fitting out using a small wrench, 1/4" or 5/16". NAPA might have the gauge fitting as well as the line, take the old one with you. The block should have a 1/4" pipe threaded hole, just remove the oil line fitting and install a plug of the same thread.
Joe | | | | | Joined: Feb 2004 Posts: 29,951 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,951 | I think the hole in the block is usually 1/8" pipe, not 1/4". Copper line seems to be more durable than plastic, and it also looks more period-correct, if that matters to you. Jerry
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Dec 2011 Posts: 33 New Guy | | New Guy Joined: Dec 2011 Posts: 33 | Thank you for the info. Pep boys have a 6 foot roll of the copper tubing. My only concern is how to get the small roll straightened out without kinking it. Have any of you had that issue or does it unroll and straighten out without to much fuss? | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Just be careful with it. It unrolls easily and can be bent without kinking it (unless it is a really thin-walled tube).
| | | | | Joined: Mar 2011 Posts: 229 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 229 | once unrolled you can roll it on the floor under a piece of wood till its straight as an arrow. kind of like using a rolling pin on dough just the oposite way.
MO's 1951 chevy 3100 resto mod project
| | | | | Joined: Oct 2009 Posts: 419 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 419 | I wanted to add to this thread at this late date because I believe this is the part I need: The fitting which goes from the block to the pressure line/oil line to canister, was broken when the Blue Funk was hit by a Semi. I'm gonna stop by my FLAPS and check it out.
| | | | | Joined: Mar 2002 Posts: 9,117 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,117 | The way to deal with the gauge is to cut the line close to the gauge and get the old line out of the way. | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Make sure to make a loop in the line near the engine to take up vibration.
