3 members (Gdads51, Ponchogl, 2-Ton), 126 guests, and 3 robots.
Topics128,128
Posts1,056,670
Members48,450
How can I keep the flywheel from spinning while torquing it to spec? I don't really have access to help anytime soon and would like to take care of this myself. Any suggestions?
58' 3200 235 3-speed/OD
Clamp a pair of vise grips onto the ring gear, and let them stop against the engine block as you torque the bolts. A "C" clamp on the flywheel will do the same thing.
Done a lot of them that way. A screw driver or pry bar jammed into the ring gear can cause a burr.
1954 Chevy Half-Ton
More pix on Shutterfly
More pix on Photobucket
1958 Chevy 1/2-Ton Stepside
"Time's fun when you're having flies." ~~ OLD FROG
How about using a screw driver in the pressure plate assembly?
1951 1 Ton Completed
By the time that's on there, the bolts he's trying to torque will be covered by the clutch plate.
A 4-6" chain, one end bolted to the flywheel where the pressure plate goes and one bolted to the flywheel housing. I do it all the time... even have a picture.
http://community.webshots.com/photo/2838480110102980561KKJENH
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
"I love it when a plan comes together...."
Thanks alot fellas, I appreciate the help.
And one of these days I will update my Photobucket(good-times...whatever the site is called...) so ya'll can see the new setup.
That chain idea is a great one! Many moons ago I did the big screwdriver in the flywheel teeth method and wound up scraping some metal off of the bellhousing and into my eyes. I bought a flywheel tool after that, but the chain looks like the ideal low buck way to go.
LJ
Oh man, for some reason I was thinking of the pressure plate bolts!
I built these. I used old ring gear but you could just grind some teeth to fit. They work great and take about 5-minutes to install if you have to pull starter and about 30 seconds if you don't.
http://good-times.webshots.com/photo/2657411170102454676xaEfmI
http://good-times.webshots.com/photo/2257528360102454676zxeIoi
Brad, great idea! I went with the chain method since I had some readily available. I put a pressure plate bolt in, hooked the chain onto that and rapped the other end with the hook around my spring and it held it fine. Torquing the pressure plate wasn't so easy though...
