1 members (Hotrod Lincoln),
130
Mod | | | Forums66 Topics128,143 Posts1,056,494 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 547 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 547 | How can I keep the flywheel from spinning while torquing it to spec? I don't really have access to help anytime soon and would like to take care of this myself. Any suggestions?
58' 3200 235 3-speed/OD
| | | | | Joined: Feb 2004 Posts: 29,821 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,821 | Clamp a pair of vise grips onto the ring gear, and let them stop against the engine block as you torque the bolts. A "C" clamp on the flywheel will do the same thing. Jerry
| | | | | Joined: Dec 2009 Posts: 194 Shop Shark | | Shop Shark Joined: Dec 2009 Posts: 194 | Done a lot of them that way. A screw driver or pry bar jammed into the ring gear can cause a burr.
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | How about using a screw driver in the pressure plate assembly? | | | | | Joined: Feb 2004 Posts: 29,821 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,821 | How about using a screw driver in the pressure plate assembly? By the time that's on there, the bolts he's trying to torque will be covered by the clutch plate. Jerry
| | | | | Joined: Dec 2005 Posts: 547 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 547 | "I love it when a plan comes together...."
Thanks alot fellas, I appreciate the help.
And one of these days I will update my Photobucket(good-times...whatever the site is called...) so ya'll can see the new setup.
| | | | | Joined: May 2007 Posts: 226 'Bolter | | 'Bolter Joined: May 2007 Posts: 226 | That chain idea is a great one! Many moons ago I did the big screwdriver in the flywheel teeth method and wound up scraping some metal off of the bellhousing and into my eyes. I bought a flywheel tool after that, but the chain looks like the ideal low buck way to go.
LJ | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Oh man, for some reason I was thinking of the pressure plate bolts! | | | | | Joined: Dec 2005 Posts: 547 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 547 | Brad, great idea! I went with the chain method since I had some readily available. I put a pressure plate bolt in, hooked the chain onto that and rapped the other end with the hook around my spring and it held it fine. Torquing the pressure plate wasn't so easy though...
