| | | Forums66 Topics128,153 Posts1,056,849 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Spent a fair bit of time straightening out my pretzels....sorry interior windshield garnish trims. No rust as such,just lots of little dents and kinks.
I've now got them to a useable state,just need to prep and paint them.(It's too cold though!) It's funny how the little jobs really eat up so much time!
1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Mar 2011 Posts: 229 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 229 | hey snuck out to the garage for an hour this evening. finished cutting inthe reliefs for the rack and tacked them in today. also leveled out the frame on the stands. ready for a little more measuring then a little grinding so i can tack the main mustang ii cross in. thanks to the assembly manual i can get this all done with frame upside down. alot easier than right side up. i will update again hopefully soon. MO
MO's 1951 chevy 3100 resto mod project
| | | | | Joined: Dec 2011 Posts: 90 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2011 Posts: 90 | Finally bought an impact driver so I could loosen up the door striker / latch thing and move it down. Passenger door now closes nicely and even locks. Also got a new passenger side wiper arm, so I'm ready for all weather! Think I'll get to mounting my new tires and painting my wheels this weekend! Great stuff to look forward too! Joe | | | | | Joined: Apr 2011 Posts: 224 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 224 | Made it outside for a bit before sundown and replaced the battery tray. Drilling out rivets is not fun.
Dave Baird 1951 Chevy 3803Foot starters are for Stovebolters and people who need a kick in the ...
| | | | | Joined: Nov 2011 Posts: 17 New Guy | | New Guy Joined: Nov 2011 Posts: 17 | Just got a table top grinder/wire brush...now Im on to knocking off rust on some inner front fender support rods and brackets on my 1950 chevy 3100 | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Finished shimming up the running boards and got the hood bolted on. Problem is, the fenders will need to be spread out about a 1/4 inch on each side.
~Jim
| | | | | Joined: Sep 2008 Posts: 130 'Bolter | | 'Bolter Joined: Sep 2008 Posts: 130 | Finaly found a pump pulley. I don't know what it's off but i can make it work. Retro fitting a 72 toyota celica heat and A/C in my 53. Getting pics together now. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | FINALLY got the hood on and adjusted. I put the center strip on and will bend the tabs on it tomorrow. Also tomorrow I will plumb the transmission temp sender.
~Jim
| | | | | Joined: Dec 2010 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2010 Posts: 37 | Still working on replacing rusty floors and cab corners....But the motor's in and all wired and plumbed!!
Saving American history one rust bucket at a time. When they're gone, they're gone forever!
| | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | oil / oil filter change and lubed the front end... and ran out of grease in the grease gun after doing only one side... with no extra grease tube.
*sigh*.
-W | | | | | Joined: Feb 2009 Posts: 400 'Bolter | | 'Bolter Joined: Feb 2009 Posts: 400 | Got my trim ring installed, now I need to put my new throttle cable on, and add the firewall grommets and hood rubber bumpers | | | | | Joined: Sep 2010 Posts: 222 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 222 | Finished the bedsides on my 3800 (well, all but one last board on each side). I think the old girl's just about ready to haul some firewood.
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Changed my fuel filter today A while back I installed one of those clear filters, after a few hundred miles it started leaking where the end thread to the glass ...pic... too bad, i liked being able to see the particles it was picking up ...pic... installed a metal cannister ...pic... Then drove the 50 to the florist to order Mrs DADS50 tuesday delivery. | | | | | Joined: Mar 2011 Posts: 229 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 229 | finished installing the mustang ii crossmember and spring hats today. pro welder friend came over and burned it all in for me after borrowing a big miller 220v mig from another buddy of ours. had lots of help flippin the frame one way or another to get to all the areas to weld. i love cheap labor cost me a 12 pack for 2 guys for 4 hours including the welder. which is still in the garage till i dont need it anymore. been a good weekend i think i will shut it down till next week. next week i will start mocking up the suspension. later MO
| | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | Took everything off the cab of my 1948 two ton except for the glass. Getting ready for rust repair and paint when the weather gets warm. Worst places are the inner and outer cowl panels on both sides. The rest is just surface rust. Also have to fix some holes that were cut into the cab. One at the top of the window frame where it looks like someone hacked into it for an electric wiper motor, one behind the passenger seat area. Someone cut a square out of the sheet metal. Not too much work. A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: Oct 2010 Posts: 111 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 111 | This past weekend I had one of the guys at work weld up some broken frames on my seat.
Ken | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I'm with you Dad; I like to see when the thing gets full and needs to be replaced. Get yourself another one, you can never have too many fuel filters, especially if your gas tank might have a bit of trash in it. BTW did you use teflon tape on those threads?
~Jim
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | No tape on the threads, just a little bit of dope.
I did see now they sell the clear filters with 1/4 and 5/16 barbs intrigrated. No need to thread fittings on the end.
But the leak was between the glass and end. This was under cab mounted. Maybe to much vibration | | | | | Joined: Dec 2011 Posts: 110 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2011 Posts: 110 |
1959 Shortbed stepside 1/2 ton project ![[Linked Image from i236.photobucket.com]](http://i236.photobucket.com/albums/ff117/olddaze/Chevy%20truck%20project/photobucket-4342-1325944221019.jpg) | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Looks good!!! You'll be a master welder when you're through with that truck.
~Jim
| | | | | Joined: Sep 2011 Posts: 116 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 116 | Got the 248 to fire up today, 4 1/2 months at the motor shop and a couple of weeks gettting things hooked back up and it runs again! Lots of tweeks yet to do. Hope to get the tranny back in tonight when my kid gets home to help. Sure has been a project, glad the wife was on board for it, but she is looking forward to have her garage back. Hope to have photos in the near future of the entire ordeal, my kids got to help with that too! 1955 Second Series GMC"Done - A 50 Year Journey"Follow in the DITY-- No one said it was going to be easy
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | ...looking forward to those pics.
~Jim
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Wired up my transmission temp gauge.
~Jim
| | | | | Joined: Sep 2010 Posts: 1,715 back yard wrench turner | | back yard wrench turner Joined: Sep 2010 Posts: 1,715 | I rounded up the parts and tools to install my rear brakes. Got the passenger side rear put together except for the e-brake cable. I also changed the grease seals on the axle. Wayne1938 1-Ton Farm TruckStovebolt Gallery Forums1989 Silverado 1996 Mustang GT convertible When I die, I hope she doesn't sell everything for what I told her I paid for it! | | | | | Joined: Jan 2002 Posts: 2,842 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,842 |
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
| | | | | Joined: Aug 2010 Posts: 255 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 255 | Let the garage warm up a bit - then removed all 4 lever shocks. Gonna' send them to Apple for rebuild. While the truck is on jackstands, decided to put a wrench or socket on the fasteners I could get to and make sure they are snug. Fixed a small leak on fuel line. Adjusted the fan belt (got rid of the squeal), and noticed steering box is low on lube. Gonna' get some cornhead grease Saturday and top it off. Purty good day !! | | | | | Joined: Mar 2011 Posts: 229 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 229 | started to get ready for mock up of drive train. cleaned up the junk 700r4 to hook up to the 350 4 bolt. tomorrow i will get the cherry picker out of storage and try get them bolted together and sitting between the rails.
| | | | | Joined: Aug 2010 Posts: 255 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 255 | Got a leaky steering box, so I rigged up a small suction hose using a big syringe and pulled out most of the gear oil that was left in the gearbox. Filled with cornhead grease - now we will see if that slows the leak down. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I had a leak at my thermostat housing. It has an O ring and NAPA didn't have a replacement. The ring came with with the housing and they could sell me another housing. Not an option. I guess I'll check out Mr. Gasket.
~Jim
| | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | I had a leak at my thermostat housing. It has an O ring and NAPA didn't have a replacement. The ring came with with the housing and they could sell me another housing. Not an option. I guess I'll check out Mr. Gasket. Jim I used a Summit racing stat housing,they also sell replacement 'O' ring seals ,I took the liberty of ordering a couple of spares when I bought mine. I can't just pop down to the local FLAPS for stuff like this! I'm planning some garage time today,so i'll measure them up for you.
| | | | | Joined: Dec 2003 Posts: 1,144 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,144 | Swapped the 54 engine into the 48. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Thanks John, I was afraid I might have to buy a dozen sizes in order to get the right one.
~Jim
| | | | | Joined: Oct 2009 Posts: 164 'Bolter | | 'Bolter Joined: Oct 2009 Posts: 164 | Today I cut out the passenger side floor pan to get a new one fitted up.
Joe | | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | I did some metal bumping and welding on the cab. Figured it would be a good place to start, since the work was behind where the seat goes. http://share.shutterfly.com/action/welcome?sid=8Ibs2LFo3bs78Next I will tackle the patch I have to make for the other side where someone cut a hole in the panel. It has a compund curve in it, so I will have to get my sand bag out and try and match the contour. A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | not today, but this was my past Friday/Saturday afternoons with the heater core on my 1965 C10: antifreeze on the floorboard -W | | | | | Joined: Sep 2010 Posts: 575 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 575 | Over the past week I pulled apart - cleaned - and reassembled my 235 distributor, using the best parts from 3 different dizzys. http://1949chevy.com/index.php/distributor/ | | | | | Joined: Jan 2002 Posts: 2,842 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,842 | Yesterday, installed rebuilt rocker arm assembly and did a initial cold valve adjustment. Changed the oil in the rear end.
| | | | | Joined: Nov 2008 Posts: 179 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 179 | This past week,i stripped the wallpaper off the hall walls,scraped the popcorn stucco off the dining room ceiling,had my brother skim coat the walls with "mud",put a primer coat on said walls,painted half the hall walls with the color my wife chose,she decides she did not like it,so,cover THAT up with primer.Today,i'm painting the dining room,and waiting for her to choose the color for the hall.What does this have to do with the bolt? Well,when i get it all done,i can go into the garage and play!  | | | | | Joined: Sep 2010 Posts: 575 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 575 | This past week,i stripped the wallpaper off the hall walls,scraped the popcorn stucco off the dining room ceiling,had my brother skim coat the walls with "mud",put a primer coat on said walls,painted half the hall walls with the color my wife chose,she decides she did not like it,so,cover THAT up with primer.Today,i'm painting the dining room,and waiting for her to choose the color for the hall.What does this have to do with the bolt? Well,when i get it all done,i can go into the garage and play!  LOL! Is that how this thread works? I neglected to describe the diapers I had to change between all my truck work! Perhaps I'll leave those details and photos out...  | | |
