7 members (TexasJim50, 1955 1 Series, Stovebolt48, 32Fordpuchoptop, lumbersawyer, JW51, 1 invisible), 54 guests, and 0 robots.
Topics128,080
Posts1,055,946
Members48,430
#823592 02/06/2012 9:16 PM
Which of the 3 brace rods in this picture:
Brace Rods
Goes in the location shown here:
Hood Latch
I don't have the hood/latch available to check. Need to paint the correct one.
The tile they are laying on is 12". The other two are front and rear fender braces.
Dave
www.fallenherosdreamride.org
all give some
MY SON GAVE ALL
The fallen hero's dream ride is a 1951 Chevrolet 3100 with original 216
In memory of LCpl Phillip Vinnedge USMC KIA 10/13/2010 Afghanistan
2ea
8 inch long
I dont recall if there is any stamping on them.
"B" for your Hood Latch... " A " is for the front tender support and " C " is the rear fender support...
1954 Chevy 3104 3 Window Hydra-Matic in my family for over 60 Years
Once in a while you get shown the light in the strangest of places if you look at it right... "Scarlet Begonias" Grateful Dead 1974
healingbear #823603 02/06/2012 10:02 PM
The hood latch should have a 'L' and an 'R' stamped on them.
The lengths are so different for the Hood (8"), Front fender
(11")and rear fender (18") it's about impossible to get them
mixed up.
DG
Denny G
Sandwich, IL
Denny Graham #823622 02/06/2012 11:30 PM
Thanks guys. "B" are stamped L & R, as are "A". "C" are not stamped.
Denny, I don't have any near 18". "C" is 12". The fender to firewall are about 28" and the radiator support to baffle are about that length also.
Dave
all give some
MY SON GAVE ALL
Can't help ya out there buddy, I can't think of any where else
there would be a strut like that one.
That may be the rear fender, my truck is a 3600 and the kick up
and spaceing on the frame is different than the 3100. The 3100
frame is wider where the rear fender strut goes so it stands to
reason that the strut would be shorter.
DG
Just looked in the FAM at the angles on the strut and now
I'm sure those (C) are the rear's for the 3104.
Denny G
Sandwich, IL
Denny Graham #823688 02/07/2012 2:34 AM
The radiator support to lower baffle brackets are a different length.I can't remember which one is longer,left or right.
Tim
1951 3100 Chevrolet
Denny Graham #823695 02/07/2012 2:52 AM
on my 3100
front fender rod is 11"
rear fender rod is 12"
DADS50 #823733 02/07/2012 4:25 AM
Thanks. All figured out now.
Tim, the radiator supports are stamped L & R.
Dave
all give some
MY SON GAVE ALL
Stamp makes it to simple, but the right one is longer to give clearance for the crank.
DG
Denny G
Sandwich, IL
Denny Graham #823743 02/07/2012 4:41 AM
I've got a set I painted hanging on the wall,never noticed the stamp.
Tim
1951 3100 Chevrolet
bowtietim #823997 02/08/2012 4:09 AM
..yeah, when you go to put the rods in front of the radiator to the bottom apron you'll see that one of the holes is a little off center... and you can tell which way the long one goes.
