| | | Forums66 Topics128,035 Posts1,055,559 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#82360 08/31/2007 4:10 PM | Joined: Jun 2006 Posts: 70 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 70 | I've noticed the lever in my linkage is showing severe wear. The hole in the lever is so elongated, the linkage rod is about to pull through it. This seems to be a very common part to go bad. I found a pretty good one by luck in a junkyard and I'm going to order a new offset rod and linkage rod. It doesn't look like a complicated repair, but is there a certain sequence or trick to make this go smooth? | | |
#82361 08/31/2007 4:24 PM | Joined: Mar 2005 Posts: 637 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 637 | You have to pull out the transmission, but it is a rather easy and uncomplicated operation. I am going change the Hydramatic for standard shift soon on my '54 GMC (exactly the same as on a Chevrolet). It would be a good idea to change the throwout bearing while it's apart, they wear out too. | | |
#82362 09/01/2007 3:51 AM | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Are we talking Z-bar or clutch fork? Scott | | |
#82363 09/01/2007 4:21 AM | Joined: Jun 2006 Posts: 70 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 70 | My clutch lever needs replaced badly and the link that connects it with the offset rod probably needs replaced also. Offset rod may not be too bad. I thought by simply moving the nuts on the offset rod, this would allow the linkage rod to be removed from the offset rod and allow easy replacement of the lever and the link. | | |
#82364 09/03/2007 3:57 PM | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | If you are referring to the linkage that is external from the bellhousing, remove the adjustment nut and the spring and it will come right off. Reinstall in the same manner. If the releae arm is worn out you have to remove the trans as chevyman32 suggested. Fred
