0 members (),
100
Mod | | | Forums66 Topics128,080 Posts1,056,317 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 13 New Guy | | New Guy Joined: Mar 2010 Posts: 13 | Hi all,
1st post so sorry if this has been covered before. Did a search and came up empty.
The gas tank in my 65 must have a small leak and I need to either seal it or replace it. I'd prefer not getting a Chiwanese gas tank, but is there anyone making them in the good ole USA?
Just replaced the water pump about a month ago and even it was made overseas. Still bothers me having that on there.
Dan
| | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | Good luck. Maybe find a good used unit? | | | | | Joined: Mar 2010 Posts: 13 New Guy | | New Guy Joined: Mar 2010 Posts: 13 | I wouldn't mind a used tank if I can find a really clean one. I don't want to go used and end up right where I am. Just thought if good reproductions are available made here, I'd go that route.
Dan | | | | | Joined: Oct 2005 Posts: 116 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 116 | If the leak isn't major , you might fix it with the gas tank sealer that several vendors sell .
" The heart of the wise inclines to the right , but the heart of the fool to the left " - Ecclesiastes 10:2
| | | | | Joined: Mar 2010 Posts: 13 New Guy | | New Guy Joined: Mar 2010 Posts: 13 | If the leak isn't major , you might fix it with the gas tank sealer that several vendors sell . I may end up doing that, I've had good luck with motorcycle tanks in the past. It is a small leak. Dan | | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | You might try your local radiator repair shop. I've had a number of gas tanks fixed by them. | | | | | Joined: Mar 2010 Posts: 13 New Guy | | New Guy Joined: Mar 2010 Posts: 13 | You might try your local radiator repair shop. I've had a number of gas tanks fixed by them. Now that's an idea I never thought of, I'll check and see if he's game. Dan | | |
