4 members (Robert Crandall, Red75bronco, 52Carl, crenwelge), 107 guests, and 1 robot.
Topics128,127
Posts1,056,675
Members48,450
#821741 02/01/2012 2:31 AM
Mine is leaking around driveshaft input. How to replace seal? Thanks in advance!
Oft said here.... Get the shop manual for your truck... Short of that, check out the "old Car Manual Project" Search in google. It will have the pages you need.
Basically, remove driveshaft, remove yoke, pull seal (carefully), replace. I've heard the torque requirements to remove the yoke nut can be quite high (200 or more ft-lbs).
Good luck! Enjoy the process, that's most of the fun.
Highflyer, Thanks for the info. I need to get under and start cranking!
