8 members (Phak1, ShopRag, Mr Bailey, Woodcmiami, Otto Skorzeny, Biermann, 78buckshot, DadsFirstPickup),
87
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,147 Posts1,056,801 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2008 Posts: 88 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2008 Posts: 88 | Just got a Newport Engineering 12 volt wiper motor. The instructions say I cant use the original switch location or the contacts will rub against the motor. Has anyone found a way to use the original vacuum wiper switch in its original location to operate the electric wipers? Is there a source for a low profile switch | | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | Yeah... new port sells one. Did you buy the motor from a vendor or directly from new port? new port engineering / wipers check out the options/accessories section. There is a switch... and an adapter to their switch if you want to use the stock knob. -W | | | | | Joined: Nov 2005 Posts: 238 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 238 | you could put a linkage under the dash to operate a toggle switch from the stock knob. I did this on my truck to run a home made 12v wiper setup from the original vacuum wiper switch. There's some pictures here of the setup at the bottom of the page. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | what newport model number did you get? They have one that will clear the choke and one that wont I used the NE4753CCT ...pic... The switch should fit. | | | | | Joined: Aug 2008 Posts: 88 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2008 Posts: 88 | Thanks for the replies. I bought the motor from Brothers and its the NE4753CT. Great suggestions....you guys are awesome. I am concerned about the length of the optional switch from Newport but I really want to retain my original knob. With your help, I think I can make it happen. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Do you plan on using your choke in the standard location? | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | DADs50 is right on the money. You got to have one with the two "C's" in the number. I got mine from JimCarter and its a Newport motor/switch. Went in alike a breeze and all I had to adjust was one wiper blade from outside the truck. The 4753CCT fits and does NOT interfere with the choke.
Buying through JCarter I saved a few bucks because I got the 10% discount and only the actual shipping. Rockport would have been more.
| | | | | Joined: Aug 2008 Posts: 88 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2008 Posts: 88 | I definitely want everthing to fit in the stock position. I thought I had the right model...The vendor didnt advertise the fact that I had to change my choke. If I need to, I'll hopefully find a buyer for my NE4753CT and get the right model or I'll stay with my vacuum wipers. I'll do a trial fit this week end. Thanks for the heads up | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | I ran into the same problem. I purchased my newport from classic parts who at the time did not disclose the interference problem
I called Newport and they let me send it to them for a replacement model that will clear. They just charged me a small shop fee.
Try calling Newport
Good luck | | | | | Joined: Aug 2008 Posts: 88 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2008 Posts: 88 | Hey Dads50...thanks for the great pics...is your extension for the stock knob the one available from NewPort? It doesn't look like anything they have. In fact, I called them and they do not recmmend their extension if the stock choke is retained. Will you share how you made the extension work? | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | No I used a flexable drive shaft and adapted it. Mounted the modern switch under the dash. Its kinda hokey but it worked for me. ...pic... ...pic... ...pic... ...pic... Good Luck | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | you could put a linkage under the dash to operate a toggle switch from the stock knob. I did this on my truck to run a home made 12v wiper setup from the original vacuum wiper switch. There's some pictures here of the setup at the bottom of the page. You've got a great webpage of interesting pics Giles. I have great respect for you guys working on American vehicles and having parts so far away. It sure helps to have some engineering/machinist skills. I worked 2 years in Bromley and do miss the beauty of Southern England. Cheers...
~Jim
