1 members (baldeagle), 158 guests, and 2 robots.
Topics128,110
Posts1,056,241
Members48,437
what year ford hydro boost set up did you use for your truck
O5
•1952 Chevrolet 3800 pickup
---All pictures---
Moderator
Moderator
2 Offline
WOW
Question asked, 13 minutes latter, question answered.
How I love this this place.
"The Flag Pole"
1946 2-Ton grain truck
1946 3/4-ton pickup,
1953 1-ton pickup
1957 1-ton flatbed dually,
1954 Pontiac Straight Eight
thank you sir
No problem.
What I used has a 1.625" bore and was from a truck (and for one) with disc front and rear.
Don't get stuck on the Ford booster if what you find is a Dodge or GM one. They all have the same mechanism (same manufacturer)and work just as good but have different master cylinder bolt patterns. Choose the MC you want and then get the booster for the same truck.
I used the Ford because it has a removable plastic reservoir and I needed a remote one. Easy enough to make fittings to replace the reservoir on the MC with hoses.
I've used one complete with MC off of a P30 GM step van chassis on another truck.
Grigg
---All pictures---
