1 members (tclederman),
114
Mod | | | Forums66 Topics128,164 Posts1,056,966 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2011 Posts: 139 Shop Shark | | Shop Shark Joined: Nov 2011 Posts: 139 | Hi all. Well, I got the truck today. 54 5w 3100 with 235 & 3 on the tree. Will post some pics soon. Truck is in great shape and runs well, drives great, very tight, tracks straight.
I plan to make this my primary mode of transportation. I'd like to put it out to the group and ask what you feel should be done to achieve this. I want to stick with the 235 or perhaps a 261 if I can find one. Also want to keep the truck stock in appearance but make it as reliable and safe as possible.
So far I'm thinking automatic, disc brakes (front for sure and perhaps rear), convert to 12v and A/C (mandatory in FL). I'll need to change the rear and have no idea what might be a good choice.
I really appreciate all your previous advice and info. I look forward to the replies and getting into this project.
One other thing. I need the truck while this transformation takes place so it'll have to be in stages that can be done without having the truck down for weeks.
With all the crazy drivers we have here I think brakes will be a top priority along with radial tires.
As always thanks in advance for the input. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | You really only need to make sure all the systems are in proper working order to be able to use it as a daily driver. Most of the upgrades are really more for driver comfort or increased performance than really being "necessary". That said, some of what you're planning will be easy to do, and won't keep the truck off the road for too long, but others will require much alteration from stock, possibly even some fabrication and parts hunting. You may want to start with overhauling the truck in stock condition and see if you like how it drives. You may be pleasantly suprised at how well they really do. I use mine as a daily driver (exept winter months) with stock brakes, steering, and a 3 speed. Never had an issue with keeping up with traffic or stopping. I do have radial tires, definetly a good upgrade.
Bill Burmeister | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | totally agree with LONGBOX, I've been driving these 50's trucks exclusively, 365, for decades, local and long distance, with the single "upgrade" of radials - just need to keep it up to specs to be safe and keep up with the flow
Bill | | | | | Joined: Dec 2003 Posts: 1,061 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,061 | What longbox said. I would make sure all the systems work, especially the lights and turn signals.
I have been using my panel as a daily driver year around for the last 8 years and have only recently taken it down for the body work.
You will have to keep the maintenance up, brake adjustments, oil changes and lube jobs that are a little different than the new stuff, but it will work just fine.
1946 1-ton Panel 1952 1-ton Comml. W/Grain Body | | | | | Joined: Dec 2011 Posts: 110 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2011 Posts: 110 | I would upgrade to a dual chamber master cylinder. Enjoy your new ride and post up a link to some pics.
1959 Shortbed stepside 1/2 ton project ![[Linked Image from i236.photobucket.com]](http://i236.photobucket.com/albums/ff117/olddaze/Chevy%20truck%20project/photobucket-4342-1325944221019.jpg) | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | A/C is mandatory in Florida? Even with an almost 60 year old truck? | | | | | Joined: Apr 2011 Posts: 224 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 224 | A/C is mandatory in Florida? HaHa! I think he means mandatory for the driver, not the DMV! It is in Florida after all.
Dave Baird 1951 Chevy 3803Foot starters are for Stovebolters and people who need a kick in the ...
| | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | You know, I was going to type a big long response about brakes and stuff, but instead...
"What they said."
It won't be a modern car no matter what you do, it won't be as fast, fuel efficient, or a handle as well. I get to drive a friend's Mazda 3 around sometimes. I'm always amazed how little gas it burns, and how it zips around town and the highways. But you know what? Nobody waves at you. You don't get to check the oil when you fill up with gas, you can't drive with the windows down because of the "helicopter-effect". You don't even get to turn the headlights on, - the robot decides when its time. The seats are tiny, and don't have springs in them... Worst of all though, you can't drive with your arm resting out the window. I might sound crazy, but I'd rather burn more gas, go slower, and be comfortable. I once drove my '49 Pontiac sedan on a road trip (1700 miles), and although I burned twice as much gas (I got 19mpg), it was the first time I'd ever driven all day, and I wasn't sore from sitting in some miniature seat made outta foam. I also had my elbow resting on the window frame, where it should be. | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | I have a 54/3100 and it has had a major redo but i don't use the A/C i have a rear slider window and with that and the floor vent and the windows down it is comfortable even in 95 degree weather. no windblown hair and noise like Mr. Lang said. i agree with the brake upgrade and their kits to make it disc on the front with out having it out of commission for too long.
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Dec 2003 Posts: 1,061 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,061 | You have A/C, open the windows and the cowl vent, works Great and does'nt put any additional strain on the engine.
1946 1-ton Panel 1952 1-ton Comml. W/Grain Body | | | | | Joined: Dec 2011 Posts: 99 Shop Shark | | Shop Shark Joined: Dec 2011 Posts: 99 | You have A/C, open the windows and the cowl vent, works Great and does'nt put any additional strain on the engine. Agreed.  | | | | | Joined: Dec 2011 Posts: 90 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2011 Posts: 90 | If it goes, turns and stops the only thing needed to daily it is a fearless sense of adventure and a tool kit stashed away somewhere. I drive my all original 51 4400 daily! Fun!!! | | | | | Joined: Apr 2010 Posts: 160 'Bolter | | 'Bolter Joined: Apr 2010 Posts: 160 | Reminds me of the strangest combo I ever saw. Customer bought a 59 Chev convertable with a 6 cyl engine and AC. | | | | | Joined: Sep 2010 Posts: 1,717 back yard wrench turner | | back yard wrench turner Joined: Sep 2010 Posts: 1,717 | Everyone says why A/C in Florida? 100% humidity with 95+ degrees is why. I can't walk outside and get the truck started before my shirt is wringing wet. My convertible Mustang stays in the garage during the hottest summer days. A/C is a necessity in Florida!  Wayne1938 1-Ton Farm TruckStovebolt Gallery Forums1989 Silverado 1996 Mustang GT convertible When I die, I hope she doesn't sell everything for what I told her I paid for it! | | | | | Joined: Dec 2011 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2011 Posts: 35 | I drove 40-50K a year for 30 years, and the past 8 behind the wheel of a '57 3200 235 3 speed.It is my May-Nov. primary ride. In all those years I have always had great tires, brakes, shocks, sway bars,constant maintaince and that has been the best and safest investment I have made in my opinion.
'57 3200
| | | | | Joined: Nov 2011 Posts: 139 Shop Shark | | Shop Shark Joined: Nov 2011 Posts: 139 | Thanks for all the great responses. Great words of advice. Definitely going to upgrade to dual master cylinder and radials. Anything else can wait. Gonna drive the truck for awhile and enjoy it.
I agree with you all about the natural A/C. Works great and I'm quite happy with that. Problem here is I sit in a lot of stop and go traffic at rush hour (morning & afternoon) so no breeze. Also lots of rain in the summer so windows are up. Plus with the 95 degree 90+ percent humidity it's brutal.
| | | | | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | For me,it'd be the M/C,disc front brakes,roller wheel bearing conversion,radials,Halogen headlights and an alternator. All the rest is nice but more a personal choice kinda thing. The stuff I listed for a daily driver,unless you're willing to compromise a little on safety,comfort and convenience,are the minimums,in my opinion. Of course,with MY budget,the minimums are considerably lower than that.  Speed | | | | | Joined: Sep 2010 Posts: 698 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 698 | Small block V8, Auto trans, Power steering, power disc brakes, A/C. It's best of all worlds. oh yeah, a killer stereo system too.
My Fleet: 19411953195919651966 1953 Willy's Pickup John Vegetarian- old Indian word for bad hunter
| | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | In regards to A/C, those vent windows work great too, adjustable forced air induction
| | | | | Joined: Dec 2011 Posts: 99 Shop Shark | | Shop Shark Joined: Dec 2011 Posts: 99 | You could always just get a late model GM with all of the frills and creature comforts that you need, and relinguish the classic pickup to just backup duty.
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | That, I'm sure, works for you guys in WI. and those above the 49 parallel but for us below the 32nd parallel where the temps can get really HOT and doesn't cool down much at night, (last summer we saw 107 degrees) and where bodies have acclimated thanks to Dr. Carrier and his air conditioner invention, air in an old truck is not a bad idea.
~Jim
| | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | Don't forget the sliding rear window.
| | | | | Joined: Oct 2011 Posts: 71 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 71 | I use my 51 GMC (100) daily up here in British Columbia! I rewired the truck (American Autowire), put in a Vintage Air heater/defroster, radials, and the old 235/4 speed combo is super reliable...I even drive it in the snow!!!! | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I also used American Auto Wire (Highway 22) and couldn't be more pleased.
~Jim
| | | | | Joined: Sep 2010 Posts: 698 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 698 | My wife won't go out to dinner with me in the truck(s) unless I agree to run the a/c.......
