8 members (Steveoreno, 1955 1 Series, 55shaker, 4tttt8, Waveski, Joe H, RdsLessTaken, 1 invisible),
75
Mod | | | Forums66 Topics128,180 Posts1,057,164 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2010 Posts: 6 New Guy | | New Guy Joined: May 2010 Posts: 6 | was it late 36 or 37 when steel replaced wood inthe dash support and the door pillar post on the cab? this is in reference to pu and truck cabs(low cab design) can the later version steel be used in the repair of a 36 cab that had wood originally? does any one make a kit to do this? answers to [email protected] | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | The 37 pickup was the first year for ALL metal. I believer the low cab 36 and the 37 do share a couple things but not sure what.
There is a guy who sells wood kits but can't remember his name. I think he has a web site....KC Wood or something like that. Others may chime in. | | | | | Joined: Feb 2011 Posts: 583 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 583 | KC Wood Mfg. 470 Rock Church Rd SW Willis, VA 24380 1-540-789-8300 chevywood.com
Mr. Goodwood - Classic Wood Mfg. 1006 N. Raleigh Street Greensboro, NC 27405 336-691-1344
Hope this helps.
1939 Chevrolet Stake Truck
| | | | | Joined: Mar 2006 Posts: 143 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 143 | 35 & first half of 36 cabs were tall with a flat back & top and had a lot of wood inside. They had 3 hinges for the door. The last half 36 had a rounded top, 2 hinges and only 3 pieces of wood -- apiece behind the dash and one in each "A" pillar. I'm not familiar with the 37 but have heard there are differences-- KC Wood has wood kits( all precut and drilled). Pertty expensive but it will take a LOT of work to make your own. Good luck. | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | No wood in the 37 cab and, even though the 37 cab looks like a 36 2nd cab in design and style, they are not the same as there are subtile differences between them.
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | |
