0 members (),
99
Mod | | | Forums66 Topics128,113 Posts1,056,619 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2006 Posts: 98 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2006 Posts: 98 | Was wanting to know if anybody had used the lmc suspension parts on their trucks?Doin a frame off resto on my '60 and gonna rebuild the entire frontend.Never had any personal experiance with them and wanted to get feedback on quality and fit before I dumped a few hundred in parts.
| | | | | Joined: Oct 2009 Posts: 426 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 426 | I used LMC for my frontend rebuild and didn't have any problems. If doing the ball joints...double check they have the same taper. Every company has sent wrong parts before. Are you just wanting to replace or are you upgrading the brakes as well? The comlpete brake kits are affordable and supply 90% of the parts to rebuild the front ends...minus idler arm and pitman arm, plus you upgrade the ball joints to the newer 74 style. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | halfpint33.....before you overspend on parts and shipping I'd give the local guys a shot at the parts. While they may not have them on stock they can get them overnight most of the time and no shipping charges either. Be sure to look around. LMC is reasonable on lots of stuff and on some they are WAAAAY overpriced.... and don't forget, there are some vendors that give a stovebolt discount if you don't find the parts locally. | | | | | Joined: Aug 2006 Posts: 98 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2006 Posts: 98 | Thanks fer the info jon1963 & Achipmunk.I had tried NAPA and O'Reileys awhile back and some things they could get and others they couldn't.I think I'm gonna keep the drum brakes.The thought on this is to be as close to stock as possible.Will do power brakes/steering though. | | |
