6 members (Gdads51, tclederman, sron48, FAST55, Hambone, cmayna), 149 guests, and 1 robot.
Topics128,111
Posts1,056,258
Members48,437
#820200 01/27/2012 1:58 PM
Was wanting to know if anybody had used the lmc suspension parts on their trucks?Doin a frame off resto on my '60 and gonna rebuild the entire frontend.Never had any personal experiance with them and wanted to get feedback on quality and fit before I dumped a few hundred in parts.
Current project . . . 1960 LB stepide Chevy
I used LMC for my frontend rebuild and didn't have any problems. If doing the ball joints...double check they have the same taper. Every company has sent wrong parts before. Are you just wanting to replace or are you upgrading the brakes as well? The comlpete brake kits are affordable and supply 90% of the parts to rebuild the front ends...minus idler arm and pitman arm, plus you upgrade the ball joints to the newer 74 style.
http://s971.photobucket.com/albums/ae197/jon63c10
1963 c-10 shortbed stepside 427 BBC T16 HD 3 speed
1963 c-10 shortbed fleetside 348 "w" 1st gen big block & powerglide
halfpint33.....before you overspend on parts and shipping I'd give the local guys a shot at the parts. While they may not have them on stock they can get them overnight most of the time and no shipping charges either. Be sure to look around. LMC is reasonable on lots of stuff and on some they are WAAAAY overpriced.... and don't forget, there are some vendors that give a stovebolt discount if you don't find the parts locally.
Thanks fer the info jon1963 & Achipmunk.I had tried NAPA and O'Reileys awhile back and some things they could get and others they couldn't.I think I'm gonna keep the drum brakes.The thought on this is to be as close to stock as possible.Will do power brakes/steering though.
