| | | Forums66 Topics128,042 Posts1,055,597 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2011 Posts: 42 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2011 Posts: 42 | I recently purchased a new rubber headliner retainer for my 1959 Apache and it seems that the rubber retainer is much larger and heavier duty than the retainer that I remember removing years ago. I'm posting s few pictures to see if anyone else has had the same experience. The headliner retainer that I purchased seems to weigh a few pounds and is extremely difficult to put in. Headliner retainer Size of retainer shown here: Retainer Size Thanks in advance for any feedback. | | | | | Joined: Sep 2010 Posts: 166 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 166 | Did mine last summer, What a BIOTCH!!! Tried using dish soap to lube it up, didn't work. Finally my wife and I got it in by lubing it up with petroleum jelly (Vaseline), and lots of cuss words. Probably the worst part of the whole body off resto! BTW, my retainer came from Classic Parts, maybe someone makes one that's easier to install? Darren | | | | | Joined: Jun 2006 Posts: 693 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 693 | i could have written the same post as durwoods. I bought it from CLassic, and did mine this past summer. I, too, consider this the worst task i undertook as well. it was hot in the cab that day and i struggled for 8 hours with it... i ended up hot, tired, and dirty. it came out well, though headliner | | | | | Joined: Jan 2012 Posts: 843 'Bolter | | 'Bolter Joined: Jan 2012 Posts: 843 | still no tips on how to replace liner do you put rubber in first
| | | | | Joined: Jun 2006 Posts: 693 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 693 | no one in this thread asked for tips on how to install it  but, yes, the rubber goes in the roof first (round/bead side in), then the headliner is put up and the lip is pulled outside of it to hold it up. the rubber shown is exactly like the one i installed. it will go in with some lubricant (i used dish soap), something dull to push it in, and perseverance. there is no easy way to do it. | | | | | Joined: Dec 2011 Posts: 42 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2011 Posts: 42 | Thanks everyone for the tips, pictures and fair warning of this task! | | |
