2 members (Otto Skorzeny, Still At It), 159 guests, and 0 robots.
Topics128,109
Posts1,056,268
Members48,439
#819808 01/26/2012 4:31 AM
does any one know the bearing number for axle bearings for a 53 3100?
3B Offline
Hy brokenhead, if you're asking about the rear wheel (outer) bearing, the SKF p/n is R1502EL $62.79 at RockAuto, hope that helps.
3B #819899 01/26/2012 3:28 PM
I wonder why I have(National)R1502CL? The seal number I have is CRC 18695.
You Tube
ODSS Lawman
ODSS Lawman
I'd shop that price, seems a little high.
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
The bearing is a R1502EL (same number for Timken, National or Bower (now NTN). The seal is National 414045 (also Timken number). Try Frugal Mechanic, it gives you several options (including Rockauto, where I bought for it was cheaper) like Parts Train, Autoparts Store etc. These are, as 3B stated for outer (wheel) for inner (differential) number is KA 11445 Y (Bower/BCA)
very nice fellas, thank you. I really didn't want to tear the rearend apart to find the number, I will definitely record it into my little project book...
