1 members (klhansen),
98
0
Mod | | | Forums66 Topics128,126 Posts1,056,356 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | does any one know the bearing number for axle bearings for a 53 3100? | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy brokenhead, if you're asking about the rear wheel (outer) bearing, the SKF p/n is R1502EL $62.79 at RockAuto, hope that helps. | | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | I wonder why I have(National)R1502CL? The seal number I have is CRC 18695.
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | I'd shop that price, seems a little high.
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: Jan 2010 Posts: 166 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 166 | The bearing is a R1502EL (same number for Timken, National or Bower (now NTN). The seal is National 414045 (also Timken number). Try Frugal Mechanic, it gives you several options (including Rockauto, where I bought for it was cheaper) like Parts Train, Autoparts Store etc. These are, as 3B stated for outer (wheel) for inner (differential) number is KA 11445 Y (Bower/BCA) | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | very nice fellas, thank you. I really didn't want to tear the rearend apart to find the number, I will definitely record it into my little project book...
