1 members (Hotrod Lincoln),
72
0
Mod | | | Forums66 Topics128,049 Posts1,055,680 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2003 Posts: 1,132 Shop Shark | | Shop Shark Joined: Mar 2003 Posts: 1,132 | I have put new bushings and bolts in the rear spring hangers to try to tighten up the suspension on the 49 Sub. Won't be able to tell if it did any good until spring. Winter has arrived with a vengeance. I want to try to install a rear sway bar but have no idea where to start. Is there a universal type being sold that might work? Also where and how do they attach? I have heard the term "Panhard Bar" and wonder what this is. All help appreciated.
Weeds | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | weeds,cpp offers a rear sway bar,not sure if it's what your after. sway bars Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Nov 2001 Posts: 438 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 438 | Weeds
Panhard bar is a bar attached from frame to rearend to prevent lateral (side to side)movement. It is usually used on four link or triangulated set up to keep rear end centered so it won't bend the "links" upon hard cornering or heavy foot syndrome if you have big engine. en.wikipedia.org/wiki/Panhard_rod
Opportunity is missed by most people because it is dressed in overalls and looks like work. - Thomas Edison Things may come to those who wait...but only the things left by those who hustle."-Abraham Lincoln
| | | | | Joined: May 2007 Posts: 321 Shop Shark | | Shop Shark Joined: May 2007 Posts: 321 | Hey Weeds, What rear end are you running? On my pickup, I installed a 10 bolt camaro rear end and used the camaro rear sway bar as well. | | | | | Joined: Apr 2005 Posts: 381 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 381 | I used a rear sway bar from Chassis Engineering. I like it better than the one CCP sells. It was the shape and the hardware that I liked better from the C.E. sway bar. Price is comparable between the two. | | | | | Joined: Sep 2008 Posts: 293 'Bolter | | 'Bolter Joined: Sep 2008 Posts: 293 | A front sway-bar will make a bigger difference than a rear one. So, if you do not have either, get a front sway-bar first and see how you like it: if it is not enough, then get a rear one. Using only a rear sway-bar is not recommended as it could create an imbalance in the vehicle that could cause problems in hard turns.
'57 Chevy Suburban; '70 Chevy Impala.
| | | | | Joined: Mar 2003 Posts: 1,132 Shop Shark | | Shop Shark Joined: Mar 2003 Posts: 1,132 | Bowtietim, 49bourbon, pplummer, wbrowne, and wave57. Thanks for all your replies.
I am running an 84 GMC 1/2T rear end. Same in front and I am using the sway bar that came with the 84.
I will check out CCP and Chassis Engineering to see what they offer. I am trying to visualize the installation as it applies to my 49 Sub.
Weeds | | | | | Joined: Jul 2009 Posts: 367 'Bolter | | 'Bolter Joined: Jul 2009 Posts: 367 | I have a 84 1ton chevy. It has front and rear bars. If you have 84 suspension the 1 ton stuff will probably bolt up. the front bar is 1 1/8 in and the rear is 3/4. The spring mounts I believe are about the same. Next time you see one in a parking lot look underneath. | | | | | Joined: Nov 2001 Posts: 438 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 438 | Weeds I shot a couple pics over the weekend of sway bar. They are iphone pics so not greatest but you can get the idea. I had to fab some brackets from angle iron for them to attach to. Then I uses all thread a with some thick wall tubing over it to get the rod length correct. Rear end is from 69 Nova. http://good-times.webshots.com/album/579455404QkfEHL?start=0
| | | | | Joined: Mar 2003 Posts: 1,132 Shop Shark | | Shop Shark Joined: Mar 2003 Posts: 1,132 | 49bourbon, thanks for the pics. Your setup looks like what I would like to do. What sway bar did you use? Is it from a junkyard or from one of the aftermarket suppliers?
Weeds | | | | | Joined: Nov 2001 Posts: 438 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 438 | Weeds The burb has been a long process due to kids and life. I bought it several years ago and pretty sure it was CPP but probably all about the same. I bought it specific to the year of rear end(69 Nova). I had then modified brackets/roads to fit.
| | | | | Joined: Oct 2007 Posts: 725 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 725 | Hiya Weeds,
Ok, sway bars. Just about anything will work if the width is right and the bar you have gets around the diff bulge in the rear end. I wouldn't go heavier than one" in the rear; it needs to be a bit softer than the front end. Most folks attach the bar to the rear end with the "arms" pointing forward along the frame. Rear sway bars seem to work better if the arms are kept parallel to the ground. Use links from the FLAPS or make them yourself. I believe it is most common to mount the mounts for the links on the outside of the frame. That's it! The bar's only job is to help avoid body roll by loading or unloading one side or the other. Somebody much smarter than I am can come along with whatever math you may need.
very best wishes,
Les
| | | | | Joined: Mar 2003 Posts: 1,132 Shop Shark | | Shop Shark Joined: Mar 2003 Posts: 1,132 | 49bourbon, I know only too well how long it takes to do one of these Burbs. Took me 8 years and thats with me even being retired.
Roadmarks, thanks for the reply and the information. I have a fairly complete machine shop and can fab what I need. If I can just find the right bar I think I can manage to get it installed.
Weeds | | | | | Joined: Oct 2007 Posts: 725 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 725 | Hey Weeds,
I forgot to add to the above that most 70s - 80s mid sized GM sporty cars have a decent rear bar. Camaros, too! You need a width so the bar comes just outside the frame. To prevent a bind, keep the arms more or less level. I got a pair of short links from O'Reillys for $4.00 each and built the mounts to suit. I used the brackets that I took off the car with new bushings for another $12.00. I think you'll find it a walk in the park! | | | | | Joined: Nov 2001 Posts: 438 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 438 | Weeds I thought I posted a reply earlier but seems did not make it to the thread. I believe I ordered from CPP (several years ago)but all are probably same manufacturer. Just make sure you order for the year and car style the rear end came out of and it should work.
