| | | Forums66 Topics128,089 Posts1,056,364 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2000 Posts: 90 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 90 | I've got a floor shift 3-speed transmission with the casting number 590715. Supposedly came out of a 1946 Chevy truck, however it doesn't match what's shown in the shop manual--it's a lot beefier in shape and weight. Did Chevy offer a heavy duty 3-speed?
1959 Chevrolet 3800 Pickup 1937 Chevrolet GC Panel Can you still call it a barn find if it's your barn? | | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | Are you sure its a 3 speed or is it a 4 speed and you just haven't found reverse. A picture would help a lot. | | | | | Joined: Jun 2000 Posts: 90 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 90 | Here's a link to a photo. It's a 3-speed, top left shift position is reverse. I found some additional info on the VCCA site that these were leftover 1933-36 Chevy transmissions used after the war in 1946. 1946 Chevy Transmission
1959 Chevrolet 3800 Pickup 1937 Chevrolet GC Panel Can you still call it a barn find if it's your barn? | | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | That could very well be what it is. I don't have a book that shows casting numbers of the 30's. | | | | | Joined: Mar 2003 Posts: 315 'Bolter | | 'Bolter Joined: Mar 2003 Posts: 315 | That transmission was used in GMC's from 1935 to 1936. Don't know what the application was for Chevrolets. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | That is what I would call a 1932-36 truck, or 34-36 pass transmission. 1932-33 pass is the same except it had a free wheeling housing on the rear.
See the USA in your vintage Chevrolet! My Blog | | |
